Monkey 252 Posted October 23, 2014 What is the secret? I attempted Siser glitter today. Didnt go well at all. First attempt I thought blade was set right but barely scored it....trash can. 2nd attempt after setting blade right, it cut it what seemed nice and through, but when peeling it pulled up in some spots and seemed to tear like wet paper. Luckily it was for a hoodie my wife wanted me to make her, and not a real customer. Which is why it was something for her, hoping to figure it out. I only bought 2' of it to play around with and well....its basically all in the circular file. Was a bit upset I ordered Black Silver and got regular Silver instead but seems to be the norm lately with orders. Share this post Link to post Share on other sites
jarrotto 78 Posted October 23, 2014 Did you use a 60 degree blade to cut it? I did a lot of test cuts the first time I cut glitter flake from Stahls. Share this post Link to post Share on other sites
Monkey 252 Posted October 23, 2014 Yeah new Clean Cut 60 degree blade. Just put it in the holder. Share this post Link to post Share on other sites
101LEDs 100 Posted October 23, 2014 I got some to try also. I noticed it felt about as thick as some reflective I had and cut it like it was the same thing. Raised the pressure an indicated 40g and did 2 passes, it came out with no problems. Probably could of used a bit less pressure. 60 degree blade. Share this post Link to post Share on other sites
jarrotto 78 Posted October 23, 2014 How detailed is your design? I mostly used glitter flake with thick designs and tried to stay away from anything with thin strips or thin sharp angled pieces.It was a pain for me to weed cause the cut lines were hard to see. I do have better lighting now but haven't cut any in a while. Share this post Link to post Share on other sites
mfatty500 456 Posted October 23, 2014 What kind of cutter are you using Monkey? I have never had good luck cutting glitter with Clean Cuts, for what ever reason i don't know, but I use some cheap chinese blades, however i don't know what brand they are, as my supplier won't tell me. But they work for me. I cut 99.99% of glitter, probably 1000 feet or more a month. I can cut some pretty small detail stuff with it no problems. Maybe put your file on here or pm me and i'll try to cut it if you like. But first let's start with your machine. Mike Share this post Link to post Share on other sites
Go-C Graphics 856 Posted October 24, 2014 I got some carbon fiber HTV that I couldn't cut. I was using a clean cut 60*. I played with is for 20 min and gave up. The next day I switched to a 45* I had and reset everything. This time I was able to get it to cut without a problem. I don't know if switching from a 60* to a 45* made the difference but it worked for me. I read the direction for the HTV and it said to cut it with a 35* blade. Share this post Link to post Share on other sites
xpaperman 719 Posted October 24, 2014 I would check your pressure. My experience with glitter is it requires more pressure. Might want to slow the speed down a tad too.... I always use 60 deg blades. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted October 24, 2014 I just did a whole mess of Cheerleader parent hoodies and other than dialing way up on pressure had no issues. I used my monster Summa 60deg blade because I didn't want to wear out my fairly new clean cut 60. I cut regular HTV around 65g and was at 150 by the time I got it cutting clean. Once I got it there then no issues although the stuff isn't very tough so you really have to watch the real extreme angles or you can rip it weeding. Notice it's not called Siser Easyweed Glitter just Siser Glitter. LOL It sure does make things go POP though. In typical fashion once the original order went out and the other parents say the product there came another whole order for more. I ordered a lit of extra because that almost always happens. Share this post Link to post Share on other sites
djque 246 Posted October 24, 2014 I cut glitter flake on my graphtec with 2 passes, pressure 23 and speed 10 with a cleancut 60* with no problems. My blade is adjusted so you can see the cut lines. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 24, 2014 Have any of you used siser video flex glitter? More like silver speckled but it fits like regular siser and is a lot cheaper than regular glitter. I sell a fair amount of it here. 1 Share this post Link to post Share on other sites
OWJones 1,981 Posted October 24, 2014 Have any of you used siser video flex glitter? More like silver speckled but it fits like regular siser and is a lot cheaper than regular glitter. I sell a fair amount of it here. I've got a roll of that - pink with silver fleck - that I bought off of a forum member - it cuts just like regular Siser and hasn't given me any problems. My sister-in-law bought a pack of Cricut brand glitter HTV and asked me to cut it for her and that stuff was horrendous to work with. When it was done, I told her never to bring me that stuff again. It was tough to cut, tough to weed, easy to tear, etc. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 24, 2014 I've got the pink, red, silver, gold and blue so far. It's so easy to work with Share this post Link to post Share on other sites
Monkey 252 Posted October 24, 2014 Im using a SC. I have a small piece left so may try bumping pressure up. Its not a super detailed piece of the image. I used black easyweed to get it done. I might give videoflex glitter a try. I was just wanting to try something different to push. I think Ill like the videoflex a bit better as the regular glitter doesnt seem like it will last long before its all flaked off. 1 Share this post Link to post Share on other sites
xpaperman 719 Posted October 25, 2014 If your looking for some great looking glitter that pops and gets peoples attention, look at Glitter Flex Ultra. I get mine from Specialty Materials Company. Now, this stuff is thick and takes a ton of down force for sure, but..... Once I used it the girls around here went nuts. My little sample of one color turned into an order of 8 rolls of different colors! 1 Share this post Link to post Share on other sites
101LEDs 100 Posted October 25, 2014 Here is one I did today. Share this post Link to post Share on other sites
Monkey 252 Posted October 26, 2014 looks REALLY good...is that regular glitter or the videoflex glitter? 1 Share this post Link to post Share on other sites
101LEDs 100 Posted October 26, 2014 That is the regular Siser Glitter in purple. Used the flash so some sparkle would show up. Share this post Link to post Share on other sites
Monkey 252 Posted October 26, 2014 Darn it, now gonna make me try it again lol. Guess next order Ill throw a couple of feet in again. Share this post Link to post Share on other sites
101LEDs 100 Posted October 26, 2014 It works good, just go with too much pressure and back it off. If it doesn't cut perfect the first try you can not save it. Share this post Link to post Share on other sites
Monkey 252 Posted October 26, 2014 Yeah my pressure was at 30 like normal, Ill bump it up to 40 and see what it does. I have a little left I may try ti tomorrow after I fill some orders. Sucks my order said out for delivery today....but then later in the day tracking changed to "On truck to be delivered next business day" so my plans on cutting a bunch of HTV tomorrow has been changed. Have a 25 shirt order I was hoping to do tomorrow but....not now. So now just a banner and a couple 3 color decals and maybe a last ride on the bike for the year. Share this post Link to post Share on other sites
mfatty500 456 Posted October 26, 2014 I believe the Siser and the Specialty Materials is the same product. Correct me if I'm wrong. Share this post Link to post Share on other sites
xpaperman 719 Posted October 27, 2014 The Siser glitter and the glitter I got from Specialty Materials are two TOTALLY DIFFERENT PRODUCTS! Now, the glitter from SM may be Siser.... I don't know.... but there is no comparing the 2! The SM glitter is WAY better. Share this post Link to post Share on other sites
Monkey 252 Posted October 27, 2014 What differences is there with them? Share this post Link to post Share on other sites
xpaperman 719 Posted October 27, 2014 The Siser, once installed, appears to have like a clear coating over it. Like a protective coating.... to me it kinda dulls the sparkle of the glitter. It is also a thinner material to cut. This other stuff from Specialty Materials, you can actually touch and feel the glitter. It sparkles like crazy and there is no coating on it. In the same line of vinyl the also have a peel and stick version. I have been using these for car window decals. The silver glitter and the gold..... I cut the school logo so folks can put them on their cars. They love it! Those two colors seem to pop the best off of tinted glass (which everyone here in Texas has...LOL) Share this post Link to post Share on other sites
