PatrickR 37 Posted February 12, 2017 I volunteer as a high school archery coach and it was time for senior night. We needed something to present to our graduating archers. I found these 7.75" glass trivets at the dollar store (for $1) and decided to give them a try as a plaque. I used 8 mil sandblast vinyl cut on my Graphtec and placed the stencil on the textured side of the glass. Blast media was 80 grit aluminum oxide from Tractor Supply shot at 60psi. 8 Share this post Link to post Share on other sites
Jburns 239 Posted February 12, 2017 THAT my friend is a clean sandblast job. Looks great. Share this post Link to post Share on other sites
security802 686 Posted February 12, 2017 Great looking work Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 12, 2017 nice work Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 12, 2017 Looks awesome! For glass you can use cheap vinyl too and it will resist plenty good. I find that to be one of the good options to use the Green Star vinyl for. It's thick and resists good while still removing easily. 80 grit is plenty aggressive for glass too but will gradually break down if you are using it in a cabinet. Share this post Link to post Share on other sites
Cal 393 Posted February 13, 2017 Really nice start, but be careful... you might get hooked! Cal 1 Share this post Link to post Share on other sites
Go-C Graphics 856 Posted February 13, 2017 It looks great...... That's a nice affordable idea. 17 hours ago, Wildgoose said: Looks awesome! For glass you can use cheap vinyl too and it will resist plenty good. I find that to be one of the good options to use the Green Star vinyl for. It's thick and resists good while still removing easily. 80 grit is plenty aggressive for glass too but will gradually break down if you are using it in a cabinet. At 60psi I don't think regular vinyl would have worked. Share this post Link to post Share on other sites
darcshadow 1,626 Posted February 13, 2017 I've blasted at 60psi, with no issues, so long as the decal is not too detailed. Obviously the smaller the piece of vinyl the easier it'll lift/blow off. Applying to a textured glass like above would be the tricking part I would think. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted February 13, 2017 2 hours ago, Go-C Graphics said: It looks great...... That's a nice affordable idea. At 60psi I don't think regular vinyl would have worked. Good point, especially with 80 grit. I think I blast glass around 35-40psi Share this post Link to post Share on other sites
PatrickR 37 Posted February 15, 2017 Thanks, folks I blasted a jar last evening using some off-brand vinyl. It worked well, but the vinyl was noticeably thinner when I finished. This really is addicting... Share this post Link to post Share on other sites
