Vermonster 111 Posted September 25, 2008 Ahhh... the leaves are turning, pumpkins are being harvested, and static is building in the air...litterally Ground your machine folks. Don't worry about if it should, if you shouldn't, if you've never done it... just ground it. Yank the wire out of an old kids toy or something and just use the screws already there. Should technically cost you nothing if you have kids or if your neighbors kids leave their electronic toys outside Just simply.... 1. Back out a screw from the bottom of your machine a little 2. Wrap a wire around the screw (making sure metal from the wire touches the screw/machine) 3. Do the same to the other side on the stand. 4. Drink BEER!! Also, make sure you advance your vinyl before cutting, and gently wipe it down with one of these! Can be dollar store ones if cost is a concern... Your jobs will smell good too!! You TOO...can avoid static electricity this winter!! 1 Share this post Link to post Share on other sites
captonzoom 2 Posted September 25, 2008 Do I use this before or after I run the vinyl sheets on perm. prees in the dryer? 1 Share this post Link to post Share on other sites
Vermonster 111 Posted September 25, 2008 LMAO... use the delicate setting Share this post Link to post Share on other sites
Benr98 40 Posted September 25, 2008 Great advice, THANKS!!! Share this post Link to post Share on other sites
Muttley 0 Posted September 25, 2008 So, liquid softener won Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted September 25, 2008 Great advice, THANKS Share this post Link to post Share on other sites
knucklehead 530 Posted September 26, 2008 And the dryer sheet works great for keeping those pesky little bubbles out of your vinyl on coroplast, just clean the coro, then a light wipe with the sheet, year round. Share this post Link to post Share on other sites
Primal Rage Outdoors 0 Posted October 29, 2008 Sweet info, thanks ! :) Share this post Link to post Share on other sites
uroplatus 0 Posted November 7, 2008 Just wondering something here... If you ground the plotter to the stand and the stand is on plastic wheels, are you truely grounding it? or are you just pass static charge off to the stand instead of the plotter? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted November 7, 2008 Just wondering something here... If you ground the plotter to the stand and the stand is on plastic wheels, are you truely grounding it? or are you just pass static charge off to the stand instead of the plotter? yes,that is what you are doing. But the static electricity in the stand won't cause your cutting to be bad. The point is to get the static electricity away from the carriage and the blade holder. The electrical ground is taken care of via the grounded plug. Share this post Link to post Share on other sites
cdoc70 0 Posted November 27, 2008 Shouldn't drink beer be first? Share this post Link to post Share on other sites
sandman 5 Posted December 10, 2008 Not sign cutting related but on topic with static electricity and dryer sheets. Dryer sheets are also a great gnat repelant. In the summer we wipe our faces with dryer sheets to keep the gnats away. I usually stick one under my cap if they are bad and we are outside. On the static note if you have cloth interior in your car and you are getting zapped when you get out and touch the door you can spray it with aresol Static Guard. I keep a can in my truck. You can also remember to touch the door before you slide out of the seat and the static will discharge without shocking you. 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 25, 2013 Worth a bump *** "the leaves are turning, pumpkins are being harvested..." Share this post Link to post Share on other sites
Cal 393 Posted September 26, 2013 Thanks for this bump for all us newbies! Cal Share this post Link to post Share on other sites
OWJones 1,981 Posted September 26, 2013 So, liquid softener won�t work? Actually, if you have carpet... Many, many, many years ago, when I worked at the arcade at the local mall, we would mix fabric softener 1:10 with water and use that in an old Windex bottle to spray the carpet and keep static electricity to a minimum in the winter time... Share this post Link to post Share on other sites
TT57 135 Posted April 2, 2014 Such old posts and i am just now reading them. Good to know. Share this post Link to post Share on other sites
express2100 154 Posted April 12, 2014 DONE.........Thank you! Share this post Link to post Share on other sites
