vinylgal 2 Posted April 12, 2014 Working with the new Titan 2. Love the quite servo motor and great step up from the SC series, but I am still have problems with the o, d, R, meeting up. Leaves a sliver/tag and causes lots of work to clean up. Seems like a blade offset issue. I have adjusted the blade offset up and down, but doesn't solve the problem. Thinking it is a software issue. Any software recommendations that would solve the problem? Should I try another software? Any trial versions out there? Any ideas? Share this post Link to post Share on other sites
slice&dice 2,450 Posted April 12, 2014 SignBlazerElements is a free alternative. support.uscutter.com/index.php?/Knowledgebase/Article/GetAttachment/190/24198 While it obviously does not have the TITAN-specific drivers (the software has not been updated in years) you might give it a try and experiment with various other drivers ---- let us know what you discover. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 12, 2014 add to the overcut - I actually prefer flexi to cut from (flexistarter is the cheapest). but in scalp under cutter setting add to the overcut - by adjusting the offset you are messing up the way it cuts the corners - it has nothing to do with cuts lining up. you won't find any drivers in signblazer as the development was halted over 7 years ago when Jerry the owner died. Share this post Link to post Share on other sites
pshawny 410 Posted April 12, 2014 Is the problem specific to an existing design that you already have made or all O's, D's, and R's of all fonts? When I upgraded from a cheap cutter to a Graphtec I had to edit some nodes of existing designs because the Graphtec was so accurate and cut flaws that went unnoticed with the cheaper cutter. With SignBlazer you would just have to go down the driver drop down box trying different drivers until one worked. My Graphtec CE-6000 worked with the Compam 2500 driver I believe. Share this post Link to post Share on other sites
vinylgal 2 Posted April 12, 2014 Thank you everyone! This is exactly what I needed tonight I didn't realize I needed to change the overcut that much, but it worked!!! Phew!! My new settings are (blade offset .30 for a 45 blade, and 3.5 mm on the overcut). I was wondering about the design, and there are occational problems with that so I am glad I'm not the only one. I am amazed at how sensative these better machines are. Thanks for all of your help! 1 Share this post Link to post Share on other sites
vinylgal 2 Posted April 22, 2014 So it seemed to fix the problem for the most part, but now it's back. Changed that blade offset, overcut, and I even put a new blade in. Cutting on the Titan 2, Speed: 300 and Pressure: 39. When I change the speed it doesn't fix them problem. I have looked at the drawings and there is no problem there either. Share this post Link to post Share on other sites
vinylgal 2 Posted April 22, 2014 I have a pic and I am a total newbie. Can anyone tell me how to add the pic to my post? Share this post Link to post Share on other sites
jaybyrd 3,770 Posted April 22, 2014 Next to reply is more reply options. You can upload from there Share this post Link to post Share on other sites
vinylgal 2 Posted April 22, 2014 Perfect, Thanks! Here is the attachment. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 22, 2014 sure looks like a stray node in your graphic - can you upload that Share this post Link to post Share on other sites
vinylgal 2 Posted April 22, 2014 Here is the graphic Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 22, 2014 post the .eps file. of your design,,,, Share this post Link to post Share on other sites
vinylgal 2 Posted April 22, 2014 Hopefully this photo turns out well... same problem, cut fine with the same settings last week, but now has the same problem. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 22, 2014 OK so now post the actual cutting file Not a picture of the file. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 22, 2014 are you cutting with scalp - might be worth calling support while they are still in Share this post Link to post Share on other sites
vinylgal 2 Posted April 22, 2014 Here is the second one Text.eps Share this post Link to post Share on other sites
vinylgal 2 Posted April 22, 2014 Yes, I'll call them Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 22, 2014 looks clean in ai and scalp3 - see what support says Share this post Link to post Share on other sites
vinylgal 2 Posted April 22, 2014 Is there a phone number? Craft edge says there is no phone contact right now, just email. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 22, 2014 call usc first - not sure on support thru craftsedge as I am sincerely not a fan of the software to begin with 2 Share this post Link to post Share on other sites
TheKid 29 Posted April 22, 2014 What version SCALP are you running.? Share this post Link to post Share on other sites
signyouup 178 Posted April 23, 2014 My guess is tracking. It looks like the end location is different from the start location. Check if the little sliver is the same as your overcut setting. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 23, 2014 My guess is tracking. It looks like the end location is different from the start location. Check if the little sliver is the same as your overcut setting. huh? So the vinyl is moving side to side (tracking) . . . . Not getting that one. We have had this issue with lesser cutters but this one is doing different things in the two examples like a communication error. If it was a mh I would start with is the carriage on the track properly. But tracking and over cut just seams way out there to me. Be interested to see what support says. That one that looks like a stray node has me baffled. Is that the latest version of scalp as they had some wonkie things with a version not long ago first one if no stray node I would lean toward a communication problem and try another usb cable just to rule that out - the second one where it starts and stops in different areas I am curious about - have seen that in value cutters when too much blade out and have fixed it by adjusting the blade but that doesn't address the first picture = that is why I am saying contact support as it seams to be all over the place . . . not a consistent problem. unless the first one was a stray node and the second one was after you played with the offset messing that up. offset will show itself in the corners of boxes and points usually - overcut just means the blade goes a little beyond the end point and starts over a little to finish a cut - tracking is when the vinyl walks side to side when rolling in and out over a distance almost NEVER shown in a short area like text - more over like a 6 ft stripe . . . . messing with the wrong thing just makes it worse. knowing the terms and not messing with the wrong thing priceless Share this post Link to post Share on other sites
vinylgal 2 Posted April 23, 2014 How would you fix a tracking problem? Share this post Link to post Share on other sites
