Friedrich07 16 Posted June 26, 2013 First Few Pictures, Pretty fine detail work! Not bad for a Roland Share this post Link to post Share on other sites
tekcorps 50 Posted June 26, 2013 Nice! Is that cut vinyl? Where did you get your lanyards? Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted June 26, 2013 Great work. Share this post Link to post Share on other sites
Friedrich07 16 Posted June 26, 2013 Yes cut vinyl and I get my lanyards through One stop Inc, Fantastic pricing under $1 each when you buy in sets of 12 Share this post Link to post Share on other sites
mb20music 760 Posted June 26, 2013 So it is not heat press vinyl?? Share this post Link to post Share on other sites
Jay2703 704 Posted June 26, 2013 Heat press vinyl is a ton easier on small detail like that. Share this post Link to post Share on other sites
OWJones 1,981 Posted June 26, 2013 Hmm.... 100% polyester... I wonder how well dye sub would work on that bumpy surface? I bought a set of 10 lanyards from Conde that were a little shorter and slightly cheaper, but you had to assemble them yourself - they were made from very smooth polyester fabric... I might have to order a set and try them out - worst case I can put Siser on them instead... Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 26, 2013 Very nice work! I may have to pick up a few of those and make some promo items to hand out. Is that Siser easyweed you used? Share this post Link to post Share on other sites
sleeveofwizzard 104 Posted June 26, 2013 Nice detail on the cuts, what equipment are you using? Share this post Link to post Share on other sites
Friedrich07 16 Posted June 26, 2013 Yeh heat press vinyl is nice. I used a Roland gx24 with a 60deg blade. Not sure how the dye sub would work let me know if you try it though. Share this post Link to post Share on other sites
Friedrich07 16 Posted June 26, 2013 And I used spectra eco film but I'm sure siser would produce the same result Share this post Link to post Share on other sites
AAndrews19 53 Posted June 27, 2013 Damn, I don't have the patience for fine weeding like that. I most likely would have went with screen print transfers. Very nice. Share this post Link to post Share on other sites
mr300s 1,272 Posted June 27, 2013 You can't sublimate on dark colors If they make them in white or some light colors I would think it would work great Share this post Link to post Share on other sites
OWJones 1,981 Posted June 27, 2013 They are available in a variety of colors, including white, so dye sub is possibkeu, just not sure if it will work well on such a rough surface. Share this post Link to post Share on other sites
WHIT72 36 Posted June 27, 2013 Cool design, what is lanyard. Share this post Link to post Share on other sites
Friedrich07 16 Posted June 28, 2013 Thanks everyone, and people use lanyards to hold keys name badges and just as accessories these days! Share this post Link to post Share on other sites
