Days Won
171
Everything posted by haumana
If you cannot seem to get SignBlazer to work, you can try other cutting software. They typically will have a trial version, and then you can see if your computer can successfully communicate with your cutter to begin with.
https://www.fontsquirrel.com/matcherator
clean up the image to isolate the text, then run it by a font identifier.
Male Enhancement, Cannabis Gummies, Herbal Supplements, Oh My!
haumana replied to slice&dice's topic in Off Topic Section
The moderators are banning them as we come across them. As far as security implementations, we will need to check to see what's available for this particular platform and go from there. There was a point in time where all messages required the approval of a moderator, let's hope it doesn't resort to that again. Thank you to those who have flagged previous posts, but because the issue is so rampant at the moment, we are trying to check the forum and ban these bogus accounts as time allows us to do so. No flagging is necessary for these spam posts, as we're doing what we can to stay on them. Mahalo everyone for your patience and understanding. -
Huh, I had no idea that there was any other version than SBE, learning something new everyday
agreed. you probably need to browse to where you actually put the downloaded file at.
Laserpoint 53" and VinylMaster Cut v4.3 intermittent cut problem
haumana replied to BillBled's topic in LaserPoint Cutting Plotter Discussion
Slack is your friend. I always will pull sufficient amount of slack that the entire cut job can be done without ever pulling direction from the roll, my machine doesn't do well with tension I got laughed at because this is one of the first things I did to my machine ... I added a reflective decal, because it doesn't matter how long I've been using cutters, I sometimes still forget -
Welcome to the forum! SignBlazer is a very good place to start. The link that Slice & Dice provided is still working (it's the big blue button that says "DOWNLOAD (34.26MB)". Just know that you will need to turn off your anti-virus to install it. There is not virus or malware in the .exe file, it's just that the program designer has long since passed away, and most versions that are out there have been "unlocked" so that it's no longer in Trial Ware, and you can use it indefinitely. The down side to that is that most anti-virus programs will block the installation of it. It would help us to know what version operating system you are using, as well as how you will be connecting the cutter to your computer. You can find Copam drivers here: https://support.uscutter.com/hc/en-us/articles/360037585432-USCutter-Copam-Driver-Download
Font Geeks -- Rejoice, behold the new Pepsi logo
I do like the new font. I'm an avid Coke drinker, and will usually pass on Pepsi if a food place doesn't have Coke, so it really makes no difference to me what Pepsi chooses to do with their logo -
Cutting Master 5 Contour cutting is not supported for multi-page design
haumana replied to UO-Jeremy's topic in GraphTec Cutting Plotter Discussion
Thank you for your update. I'm sure others can learn from this.- 11 replies
- grpahtec
- cutting master 5
(and 3 more)
Tagged with:
If you're hoping to get everything back to the same point of origin, you need to make sure that you have the software request to return to the point of origin at the end of the cut.
Is this the very first thing you're trying to cut with this newly installed Graphtec, or have you successfully tried to cut something else? Have you tried using the Graphtec Studio software?- 11 replies
- grpahtec
- cutting master 5
(and 3 more)
Tagged with:
Glad I was able to assist. That's what we're all here for
I'm not seeing any visible border around the graphic. However, I've converted it to several different formats, hopefully one will work for you. Please check your email.
If you're willing to post the file or email it, then I can probably assist you. If not, you can try using a different program to edit it, like Inkscape (which is free).
[Good afternoon. I would like to know if it is possible to buy a new license for my machine since the software license was lost with my laptop and now it appears to me that it is with another email. Due to this it is not possible to recover anything I have including the Key Product with your PSN. fcortes2817@gmail.con] I would suggest you contact VinylMaster directly. [Le sugiero que se comunique directamente con VinylMaster.]
If I need to, I will recreate. When I do, I will rarely give the customer the electronic file of the work I've done, even though it would probably be the cleanest file they would ever get of their logo. If they do ask for the file, I may or may not charge them a "setup" or "digitization" fee to at least cover my time and effort. I get it though, I can sometimes clean up a logo while I'm still on the phone with customer during their initial phone call, then they are amazed - of course I send it to them water marked in a secured .pdf format. Hahaha.
You would be amazed at how many businesses that I interact with, who do not have their own artwork for one reason or another. I often dread having to recreate someone else's logo because it seems like reinventing the wheel, but it's the same wheel without any improvements
I suspect it may not be a true font, but one that's either been modified, or it's just a graphic.
Lost Pinchroll Error - Roland CJ-500
haumana replied to Palidonia's topic in Roland Cutting Plotter Support Requests
Thanks for posting your update.
Again, have you checked what COM Port your Windows machine has assigned to the cutter? Yes, VinylMaster does work with Windows 7. Sign Blazer (SBE) - I would recommend that you absolutely find out with COM Port, and manually designated it in SBE, because auto detect doesn't always work properly. I don't have an LP II, but I do have an original LP, and the machine that I needed to select from the list was the Creation PCUT 735.
But they are pretty cool looking. How much do those thing run? I know I'll never see one here. -
fc8600 FC8600-Cut Master 4 issue
haumana replied to jeffdpia's topic in GraphTec Cutting Plotter Discussion
That Graphtec J just gets to everyone one at some point. -
Have you verified which COM Port Win11 has assigned to your machine, and make sure it matches in the software? Have you also tried reaching out to US Cutter, maybe see if they have an updated driver for you, since the original LaserPointsd were back in the WinXP days.
