frizz6907 0 Posted August 26, 2014 I want to be able to show my shirt designs on my Facebook page without having to actually make the shirts. I use SCAL3 pro and I have Photoshop CS6. I'm VERY new to photoshop, so be detailed. I've attached a design and a basic image of a shirt. I don't know enough about Photoshop to be able to overlay the text and have it look decent. Maybe there's a totally different way??? I have no clue!! What's the easiest/fastest to put my designs on a shirt? Thanks!! Share this post Link to post Share on other sites
Coaster36 327 Posted August 26, 2014 When I need a proof like that I just do it in my design program. I use inkscape and just put the design on top of what you want. Its simple. Then just save it. I don't use scal but if it doesn't save as a jpeg or other useful file format just use an online file converter to change it to jpeg. 1 Share this post Link to post Share on other sites
frizz6907 0 Posted August 26, 2014 Ok, so I should download inkscape? I export my designs from SCAL as jpeg, but I have a white background. If I overlay it on something it would still have a white box. Thanks for the quick reply! Share this post Link to post Share on other sites
30-284 86 Posted August 26, 2014 Use a t shirt template and place your graphics on it and save. t shirt template.eps Share this post Link to post Share on other sites
30-284 86 Posted August 26, 2014 Sorry it came out so small but use a template like this and go from there. this was done in scalp 3, export as jpeg. Donn Share this post Link to post Share on other sites
Coaster36 327 Posted August 26, 2014 It has the white box because your saving it as a jpeg. Here are the steps. Since I dont use scal they might be different. Make your design. Just as you would cut it. Like that text. In the same file, import the picture of the shirt. Lay your design on top of your shirt Save the whole thing as a jpeg. Drink beer Id recommend saving your design as a vector before you add the shirt so you still have a cuttable version. And you can download inkscape if you want but im sure scal can handle this task. 1 Share this post Link to post Share on other sites
djque 246 Posted August 26, 2014 Ok, so I should download inkscape? I export my designs from SCAL as jpeg, but I have a white background. If I overlay it on something it would still have a white box.Thanks for the quick reply! I use a software called t-shirt mockup. I did this with it you can change the color of the shirts. 2 Share this post Link to post Share on other sites
frizz6907 0 Posted August 26, 2014 Thank you very much!! It all makes sense now and I have options!! Share this post Link to post Share on other sites
Go-C Graphics 856 Posted August 26, 2014 I use a software called t-shirt mockup. I did this with it you can change the color of the shirts. I'll have to look into that 1 Share this post Link to post Share on other sites
raymand 1 Posted August 27, 2014 I use a software called t-shirt mockup. I did this with it you can change the color of the shirts. There is still a white background on the t-shirts Share this post Link to post Share on other sites
LPWash 75 Posted August 27, 2014 Go to www.images.google.com type in the color shirt (charcoal tshirt template) you will be using. Save that image to your computer. Then open up SCAL. Click file, place image. Then find that tshirt from google images on your computer. And then add your text design. If I"m making a shirt for myself, I would measure my shoulder to shoulder dimension and then scale the shirt in SCAL. Then once you put your text , you can scale it to the exact look and actual size and you're ready to cut. ps: Don't forget to mirror / flip that image before you cut it. This method works great for text on actual walls, vehicles, etc. You can take a picture and upload it to your SCAL. Potential customers love it. Let me know if you need any help. Share this post Link to post Share on other sites
Poot25 9 Posted September 4, 2014 30-284,I snagged a copy of the template,Thanks!! djque, thanks for the you tube link,it was very helpful!!! Share this post Link to post Share on other sites
H2Ohydrographics 25 Posted May 11, 2015 grabbed a copy thanks Share this post Link to post Share on other sites
Jburns 239 Posted May 12, 2015 You can use photoshop since you have it. I do it with CS6... Save the text as a jpeg- open in photoshop- creat a layer- use magic wand to delete the white space. Open your shirt image in another pane--- literally click and drag your text onto the shirt- resize as necessary. There are tutorials on you tube- remove white space Share this post Link to post Share on other sites
pshawny 410 Posted May 12, 2015 You can use photoshop since you have it. I do it with CS6... Save the text as a jpeg- open in photoshop- creat a layer- use magic wand to delete the white space. Open your shirt image in another pane--- literally click and drag your text onto the shirt- resize as necessary. There are tutorials on you tube- remove white space If you save the design in PNG file format it won't have the white background and will save you a step. Share this post Link to post Share on other sites
TT57 135 Posted May 19, 2015 i use SCAL for my mock-ups. Like LP said. Share this post Link to post Share on other sites
painperdu 3 Posted May 19, 2015 SCAL is buggy. You certainly should download the free and open source Inkscape. Share this post Link to post Share on other sites
TT57 135 Posted May 21, 2015 i also use Inkscape. colors look better on mockup in Ink. Share this post Link to post Share on other sites
TauntDevil 19 Posted May 21, 2015 Here is a good tutorial that I gave a friend when he was trying to do the same. It is exactly the same way I do mine but I also include a bump layer as well for the waves. This is using photoshop. Link to the tutorial here Hope this helps! Share this post Link to post Share on other sites
Wildgoose 4,200 Posted May 21, 2015 I do a lot of these and have settled in on a little simpler than complicated. I typically either use This one: http://www.t-shirt-template.com/vector-tshirt-model-template/ or probably more common I download a pic of the actual shirt from Sanmar or where ever I am getting the shirt from and place in right on there so they have about the most realistic view you can get with the least effort. 1 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted May 21, 2015 I find myself copying and pasting images from Sanmar all the time. Just lay the design on top and send a low res proof. 1 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted May 21, 2015 I find myself copying and pasting images from Sanmar all the time. Just lay the design on top and send a low res proof. This is an area where the mac computer really comes in handy. The keystroke Comm+Shift+4 pulls up a little target that you can drag out a box and do a precise screen capture that saves to your desktop and works perfectly to get the pic without the added things around the edges. 1 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted May 21, 2015 with pc I just right click and either copy or save image as. I know that this doesn't work with all web based pics but it works fine for sanmar. If it weren't for replacing all my software I may have made the switch to mac the instant I started using windows 8. Share this post Link to post Share on other sites
darcshadow 1,626 Posted May 21, 2015 windows has the Snipping Tool program that does the same thing as Wildgoose suggested on a mac Share this post Link to post Share on other sites
markaurelio 0 Posted June 22, 2015 " or probably more common I download a pic of the actual shirt from Sanmar or where ever I am getting the shirt from and place in right on there so they have about the most realistic view you can get with the least effort. " dear wild goose, am a non-techie, just a t-shirt vendor. i went to sanmar and saved one pic. i have another photo saved from google images.... a quote from einstein.. which is in jpg. pls elaborate how i can superimpose the quote on the shirt. i suppose when i save this combination, it will also be in jpg? thanks for your kind assistance. mark Share this post Link to post Share on other sites
