mailman 1 Posted September 4, 2018 My image is cutting about 4 times the size of original image. I am not sure how to calibrate size. Is there a factory setting that is standard in the device units per inch. Mine was set to 1600 units per inch.Thanks, Mark Quote Share this post Link to post Share on other sites
MZ SKEETER 4,720 Posted September 4, 2018 49 minutes ago, mailman said: My image is cutting about 4 times the size of original image. I am not sure how to calibrate size. Is there a factory setting that is standard in the device units per inch. Mine was set to 1600 units per inch.Thanks, Mark Just a quick look at Vinyl Master, demo. Click FILE>CUT/PLOT>VINYL SPOOLER> ON THE RIGHT SIDE TAB IS CALIBRATION> CHOOSE CUTTER SCALE. And see what happens there.. Quote Share this post Link to post Share on other sites
mailman 1 Posted September 4, 2018 Thanks MZ SKEETER I gave it try, I set the size of test box to cut a 2"x2" square at 100% it cut a box 8"x8" . I reduced the percent to 25% and it did cut 2x2 square. My device units per inch is set at 1016 should I reduce this to 254? Thanks, Mark Quote Share this post Link to post Share on other sites
MZ SKEETER 4,720 Posted September 4, 2018 I don't use Vinyl Master, I am just throwing some info at you that I read. You will have to contact Vinyl Master. or some else with Vinyl Master will have to help you. You don't state which vinyl cutter your using,,, Does the vinyl cutter have calibrate on it.?..I only use a Graphtec, so any other I would not know. Your welcome Quote Share this post Link to post Share on other sites
mailman 1 Posted September 4, 2018 Thanks again for all your help. Mark Quote Share this post Link to post Share on other sites
darcshadow 1,641 Posted September 5, 2018 I too do not use Vinyl Master, but your setting of units per inch, assuming you have a stepper motor machine, is usually referring to number of steps of the stepper motor and 1016 is in the neighborhood of what it should be so I don't believe that number is something you should change. Until someone chimes in with anything better, I'd simply make your design then scale it down before cutting. The beauty of vector graphics they can be scaled up and down with no loss of detail. Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted September 5, 2018 They can be scaled but it's a PIA when you design something just a certain size and then not have your cutter cut at that size. I am unclear how best to dial this in with VM either. I would call their tech support and get clarification. This is a users forum so you may not get "official" info from us schlubs. There should be a way to dial in and then save that calibration so you don't have to worry about it anymore. Quote Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted September 5, 2018 Vinylmaster is great about replying to topics in this section - but they are on Australian time so could be a lag in getting that answer Quote Share this post Link to post Share on other sites
ShaneGreen 131 Posted September 5, 2018 1016 is what VM has for my LaserPoint II, so that is probably a good number like Darkshadow said. When you "Send to Cutter" it shows you a preview on a cutter. It shows the dimensions of the cut just like on a blue print. Are those dimensions reading correctly? Now they might be off a bit because of weedboxes, etc. but they should be pretty close. Also, when you send a test cut directly from your cutter, not from VinylMaster, what size does it come out? What cutter are you using so someone with that cutter can tell us if that's the right size test cut? Quote Share this post Link to post Share on other sites
mailman 1 Posted September 14, 2018 Thanks for all the help. Mark Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted September 20, 2018 As everyone has identified. The issue is scaling issue and requires a setting to be adjusted. Please see this guide:My artwork is cutting at the Wrong Size? 1 Quote Share this post Link to post Share on other sites
