unrealgraphics 0 Posted December 29, 2013 I've recently started playing around with contour cutting. Basically, I ordered some 8.5x11 vinyl for my desktop printer, to print and cut with. I am using Draw X5 for my design, and then Flexi 8.1 for my print and contour cutting. I print my design out with my printer, usually just one decal, instead of a whole page. I use FlexiSign Pro 8.1 to make my contour, and it also prints the Reg marks for me properly and all that jazz, I use my MH721 plotter with the Pen tool to help line me reg marks up, I can usually get them right on, yet my contour cut doesn't come out right. I don't really know where to go from here. It seems like its just stretching out my contour or maybe my print didn't scale correctly, not totally sure. Maybe someone can help me solve this problem. I've had success contour cutting with this same setup, but only on small items, or very very simple contours. (On the images attached, the rectangle is from me playing with the Compensation factor, which lines up good. Roughly 0.015625 of an inch off. That small margin should cause the contour to be that far off.) Any suggestions? It would be super nice to get this to work somehow, would really help out my business and my turn around times for the customers who order 8.5x11 sheets of decals. Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted December 29, 2013 Just curious, what computer operating system are you using the Flexi8.1 on? As it is only compatible with XP and older. operating systems. Share this post Link to post Share on other sites
unrealgraphics 0 Posted December 29, 2013 I'm using Windows 8.0, do you think that could be a factor, should I upgrade to a newer version? Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted December 29, 2013 Flexi tech support in the SAI forum will tell you the same thing. Vista version was not even updated til version Flexi 8.5. You will either have to go back on XP computer or Upgrade your Flexi program.. Share this post Link to post Share on other sites
unrealgraphics 0 Posted December 29, 2013 Alright, that's no problem. I had someone give me a copy of 8.1 so that's what I've been using. So, do you think that might solve me problem? Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted December 29, 2013 Ask SAI tech support.... Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted December 29, 2013 You can do contour cutting with Flexistarter 10. and the MH cutter. Can be had for under $130 on EBAY. Share this post Link to post Share on other sites
unrealgraphics 0 Posted December 29, 2013 Alright. I'll look into that. I was hoping It was just going to be a miscalculation somewhere, considering how well Flexi works on my computer. Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted December 29, 2013 Alright. I'll look into that. I was hoping It was just going to be a miscalculation somewhere, considering how well Flexi works on my computer. If you think, that is all it is, then contact SAI tech support. Share this post Link to post Share on other sites
