Jeanette Stephens 1 Posted September 21, 2018 Hi I am new & I just got a MH721-MK USCUTTER & all my files r SVG files and I want to keep them because I have some cutters that uses SVG files and I would like to know how I can keep the SVG files but I need to make the same files in vector files for my US CUTTER. Thanks Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 21, 2018 Check in Vinyl Master and see if it doesn't import .svg files. One way is to import your svg files into Inkscape.org. and save as your svg as well as an .eps file that can be imported into Vinyl Master. Share this post Link to post Share on other sites
cardudenc 151 Posted September 21, 2018 welcome , I finally have another MB peep on here. my 1st cutter was an sc model from us cutter , and the 2 programs I use to cut with is VM which came with my cutter, but then I upgraded to scalps 4 , i save all my work as an svg file where u at dn here? we have a store in surfside 1 Share this post Link to post Share on other sites
Jeanette Stephens 1 Posted September 21, 2018 I have a Hair salon in Conway 1 Share this post Link to post Share on other sites
Cal 393 Posted September 21, 2018 Welcome aboard Jeanette Share this post Link to post Share on other sites
darcshadow 1,626 Posted September 21, 2018 16 hours ago, Jeanette Stephens said: Hi I am new & I just got a MH721-MK USCUTTER & all my files r SVG files and I want to keep them because I have some cutters that uses SVG files and I would like to know how I can keep the SVG files but I need to make the same files in vector files for my US CUTTER. Thanks What software are you using? The cutter doesn't care what the file is formatted in. 1 Share this post Link to post Share on other sites
cardudenc 151 Posted September 21, 2018 our landlords original store is in Conway, the Wild West Western store. we r b side him in surfside. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted September 21, 2018 SVG format IS vector and almost all cutting programs can handle them. SVG = Scalable Vector Graphic Welcome from Idaho! 1 Share this post Link to post Share on other sites
ShaneGreen 131 Posted September 21, 2018 In VinylMaster... >File > New Document >File > Import >File Grab the file you want and then it will put you back on the blank new document. Place your cursor where you want it and left click. Click on the image to select it and then >Arrange >Ungroup to make the bits editable. You can actually import multiple SVGs to the same document. { WOOT WOOT! 100 posts! I wish my high school guidance counselor could see me now!!! } 3 Share this post Link to post Share on other sites
Jeanette Stephens 1 Posted September 22, 2018 Thanks so much it worked Share this post Link to post Share on other sites
Jeanette Stephens 1 Posted September 30, 2018 How can I put a amage in with my text, like this Share this post Link to post Share on other sites
haumana 1,220 Posted October 1, 2018 text & image. personally, i would either type out the text in design/cutting software and put a bunch of space in the lettering and drop in graphic. or two sets of the text, with the graphic in between. it's personal preference. what software are you use? Share this post Link to post Share on other sites
