Brandiland 5 Posted February 12, 2016 Alright, so I've dug around on here for a while. I can't seem to find what I'm looking for, but I've seen quite a few intelligent people, so I figured I'd start here. I'm using Signcut Pro with ARMS on a Saga 2400 cutter. I've read the instructions they give on how to align my registration marks. I even made my own registration marks at 25mm long in each direction (as suggested). I'm not sure my cutter is trying to see those marks. It's not consistent in its errors, making it very difficult to find the problem. Sometimes, when I click "ok" to cut, nothing happens. Sometimes, it trails off to the left and up as if it's looking for the registration marks, but then stops short, and begins the cut, or draw,in my case. I feel like I'm missing something. Can someone who uses the ARMS system with Signcut Pro help me? 1 Share this post Link to post Share on other sites
MZ SKEETER 4,694 Posted February 12, 2016 sent you a PM Share this post Link to post Share on other sites
MZ SKEETER 4,694 Posted February 12, 2016 Are you using the latest version of Signcut Pro like it says.1.96? I have heard Signcut has very good support, Try contacting them. Or your SAGA dealer tech support. 3) Make sure you are using the latest version of SignCut. You will need SignCut version 1.96 to support the ARMS system. This version can be obtained by going to SignCut here, not by checking for updates through the SignCut Help menu: http://www.signcutpro.com/download-signcut-productivity-pro/ And in Signcutpro you are choosing> Special Cutting Menu >SAGA ARMS contour cut from the menu? Share this post Link to post Share on other sites
Brandiland 5 Posted February 12, 2016 Correct, using the latest version, and choosing all the options you mentioned. Share this post Link to post Share on other sites
MZ SKEETER 4,694 Posted February 12, 2016 Correct, using the latest version, and choosing all the options you mentioned. Are you putting the laser correctly inside the first registration mark, lower right> then setting Origin, then Click OK to cut.? If your doing all of that, then contact your support..techs. Signcut or Saga. Share this post Link to post Share on other sites
Brandiland 5 Posted February 13, 2016 <blockquote class='ipsBlockquote'data-author="Mz SKEETER" data-cid="412830" data-time="1455299864"><p> Are you putting the laser correctly inside the first registration mark, lower right> then setting Origin, then Click OK to cut.? If your doing all of that, then contact your support..techs. Signcut or Saga.</p></blockquote> Yep, did all of that. I emailed support yesterday. Hopefully, I'll hear something soon. I'm not sure how to add a picture, or I'd show you what it looks like. Share this post Link to post Share on other sites
MZ SKEETER 4,694 Posted February 13, 2016 Next to POST button is More reply options.. Click it. and upload a picture Share this post Link to post Share on other sites
Brandiland 5 Posted February 13, 2016 Ah, got it. That's on the full version. The Mobil app didn't have that. This is the difference in cut. Also it's very jagged. Share this post Link to post Share on other sites
Brandiland 5 Posted February 13, 2016 Nevermind, pic was too large to upload. I'm giving up. Share this post Link to post Share on other sites
