joker 618 Posted December 24, 2014 Wife gave me and early birthday present. It is a ihome bluetooth speaker which sounds amazing. So today i decided to personalize it with some decals. This decal is 2.5 inches tall and about 1.8 inches wide.. Posting this so the people with the Sc model cutter can see that you can cut smaller stuff. it just takes some dialing in 5 Share this post Link to post Share on other sites
diverse designz 10 Posted December 24, 2014 Very cool. Nice decal choice Share this post Link to post Share on other sites
joker 618 Posted December 24, 2014 Yeah i believe member jonnscott shared it 1 Share this post Link to post Share on other sites
security802 686 Posted December 25, 2014 Nice work Joker 1 Share this post Link to post Share on other sites
LPWash 75 Posted December 28, 2014 Love my sc. It can cut pieces so small that I've needed magnifying glass just to weed projects. Share this post Link to post Share on other sites
Cal 393 Posted December 28, 2014 Joker, and LPWash - what blades and settings are you using? I just swapped up to the clean cut 60* blade - reset offset to .5 and it has a tendency to pull up the vinyl on sharp corners. I was not having this problem with the original 45* chinese blade that came with the machine. My speed is at 200 and pressure at 40. This is cutting Oracal 651 on my SC25. Thanks, Cal Share this post Link to post Share on other sites
security802 686 Posted December 28, 2014 Joker, and LPWash - what blades and settings are you using? I just swapped up to the clean cut 60* blade - reset offset to .5 and it has a tendency to pull up the vinyl on sharp corners. I was not having this problem with the original 45* chinese blade that came with the machine. My speed is at 200 and pressure at 40. This is cutting Oracal 651 on my SC25.Thanks, Cal too much blade can cause lifting at corners. Share this post Link to post Share on other sites
Go-C Graphics 856 Posted December 28, 2014 Too much overcut also. Share this post Link to post Share on other sites
joker 618 Posted December 28, 2014 clhyer i use a 60 degree blade bought from uscutter. I run at 200 speed and 24g pressure. with offset set at 0.35, I use these settings for htv as well and i cut 0racal 651 with these settings. my blade is set to where you can barely see the tip.. Hope this helps Share this post Link to post Share on other sites
Cal 393 Posted December 29, 2014 EL, with the settings I have I can just see a light outline of my cut on the backing paper. Go-C, is overcut the same as offset? My cutter was originally set a .30 and was not getting a clean cut in the corner. The clean-cut blades do recommend a .50 offset. Maybe I need to see what .40 will do. Joker, thanks for the info. I will just have to do some more playing around with it. Cal Share this post Link to post Share on other sites
Go-C Graphics 856 Posted December 29, 2014 EL, with the settings I have I can just see a light outline of my cut on the backing paper.Go-C, is overcut the same as offset? My cutter was originally set a .30 and was not getting a clean cut in the corner. The clean-cut blades do recommend a .50 offset. Maybe I need to see what .40 will do. Joker, thanks for the info. I will just have to do some more playing around with it. Cal It is not the same as offset. Share this post Link to post Share on other sites
LPWash 75 Posted December 29, 2014 Joker, and LPWash - what blades and settings are you using? I just swapped up to the clean cut 60* blade - reset offset to .5 and it has a tendency to pull up the vinyl on sharp corners. I was not having this problem with the original 45* chinese blade that came with the machine. My speed is at 200 and pressure at 40. This is cutting Oracal 651 on my SC25.Thanks, Cal I used the blades that came with the cutter and have reordered the same from US Cutter. Ever since I read on here that someone cut full speed all the time, I tried and now do the same every time. Pressure is at 34 for 631, 651 and 751. That number will vary when changing blades. Share this post Link to post Share on other sites
Cal 393 Posted December 29, 2014 Go-C, thanks. I see an adjustment for overcut and will experiment a little with it. Cal Share this post Link to post Share on other sites
Go-C Graphics 856 Posted December 30, 2014 Go-C, thanks. I see an adjustment for overcut and will experiment a little with it.Cal I struggled with lifting corners for MONTHS. Played around with everything mentioned here. Then I realized even .1" of overcut is too much. Now I've got an overcut of .01" and it's perfect. 1 Share this post Link to post Share on other sites
