SJay 3 Posted May 17, 2014 Anyone have any luck installing a key-span on a mac OS 10.9.3 and using it with the Titan 2. I can use it with a USB cable but it does not see the key-span serial cable. Any suggestions? Thanks Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 17, 2014 zero exoerience on a mac but on a pc there is NO need for a keyspan with the titan - very solid usb chipset on that cutter - not like the cheaper cutters Share this post Link to post Share on other sites
BannerJohn 1,324 Posted May 17, 2014 why are you trying to use the keyspan if it works with USB? Share this post Link to post Share on other sites
SJay 3 Posted May 17, 2014 I have heard so many horror stories about USB, I thought the keyspan would work best. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 17, 2014 upper end cutters are a whole different story and from what john, I and several others have experienced this one is rock solid usb. I have run graphtecs and rolands and this usb was as solid as those Share this post Link to post Share on other sites
BannerJohn 1,324 Posted May 17, 2014 The low end cutters are not true USB..the emulate USB, while the Titan and other High end cutters are TRUE USB. Share this post Link to post Share on other sites
