islandjay 3 Posted May 1, 2014 I have a Copam 2500 and I am Sign Blazer. The vinyl is 24" wide and I tell the copam to measure before cutting. The cut job is 18" by 6", so naturally I set the 18" to cut wide. Every time is does not cut all the way. At best it goes 17" and stops the cut. Does not even finish it so half of the job is still attached to unwanted vinyl. If I rotate it 90 degrees, it cuts the whole thing. What am I missing? Thanks!Jason Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 1, 2014 Are the rollers all the way out on the cop am, it measures the distance between the rollers and that becomes the max cut width. Other than that is the workspace in sb set to 20 bx 20" or so? Share this post Link to post Share on other sites
islandjay 3 Posted May 1, 2014 Are the rollers all the way out on the cop am, it measures the distance between the rollers and that becomes the max cut width. Other than that is the workspace in sb set to 20 bx 20" or so? Yes, just as wide as the paper Share this post Link to post Share on other sites
slice&dice 2,451 Posted May 1, 2014 Make sure your SignBlazer cutter setup has the correct width. Share this post Link to post Share on other sites
pshawny 410 Posted May 1, 2014 Click "Cutter" - Fit to Origin should be selected Click "Cutter", then "Setup" - Set vinyl width to 24" Share this post Link to post Share on other sites
Jay2703 704 Posted May 2, 2014 Make sure all of your design is inside of the workspace (Pink Rectangle) or you have the "Limit to Workspace" button Un-Checked in the cutter setup. 1 Share this post Link to post Share on other sites
islandjay 3 Posted May 2, 2014 I appreciate the help, but no luck. It is starting 3" into the material and cutting off 3" at the end stillWhy would not not start near the edge? it is like it has a 3" left and right margin.Any other thoughts? Share this post Link to post Share on other sites
Jay2703 704 Posted May 2, 2014 Can you post what your cutter settings look like? Share this post Link to post Share on other sites
pshawny 410 Posted May 2, 2014 Limit to workspace should be checked Share this post Link to post Share on other sites
Jay2703 704 Posted May 2, 2014 Everything looks good to me. Limit to workspace doesn't need to be checked. Share this post Link to post Share on other sites
islandjay 3 Posted May 3, 2014 I tried both checked and unchecked. When I use 15" vinyl it is fine. Share this post Link to post Share on other sites
MZ SKEETER 4,710 Posted May 3, 2014 Does it make any difference if you would use the driver for the Copam 3050 or 4050..? Wider cutters.. You could give it a try. And see if that would help. Just experimenting. Share this post Link to post Share on other sites
slice&dice 2,451 Posted May 4, 2014 This is actually in the wrong category (SignCut software) although the discussion is regarding SignBlazer -- Anyway, maybe there's something going wacky within the Copam cutter itself, when given the command to "measure before cutting" One more place to look in SignBlazer is the PRINT setup window, and verify margins are set to zero. While I cannot tell you why a PRINT function should have any effect with the CUT routine, it's possible there's an overlap of the configuration setting somehow. Share this post Link to post Share on other sites
islandjay 3 Posted May 4, 2014 They were set to zero. Still no luck. Appreciate the help so far Share this post Link to post Share on other sites
skarekrow 1,842 Posted May 4, 2014 You said it is starting 3" in and not on the near the edge... are you setting the origin point? Sorry if it doesnt apply, dont have SignBlazer or Copam. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 4, 2014 that made me think a little skarekrow - the copam only cuts the width that the rollers are set at - so lets back up to the beginning and make sure you have the rollers all the way out to the edges of the vinyl roll 1 Share this post Link to post Share on other sites
slice&dice 2,451 Posted May 4, 2014 I love a good mystery. Hopefully this one has a satisfying ending. Share this post Link to post Share on other sites
islandjay 3 Posted May 6, 2014 that made me think a little skarekrow - the copam only cuts the width that the rollers are set at - so lets back up to the beginning and make sure you have the rollers all the way out to the edges of the vinyl roll That was it! It was the rollers. makes sense now. Live and learn. thanks! 3 Share this post Link to post Share on other sites
