gcextreme 475 Posted May 8, 2013 ok ive been looking thru the forum, and trying to find out what is the best method for applying a multi-layered/colored vinyl. Should i do a wet application??? Should i use clear app tape or not? I'm trying to do my GC-EXTREME logo in RED with a yellow outlined background... I thought there was a video on here, but i can't seem to find it. Share this post Link to post Share on other sites
gcextreme 475 Posted May 8, 2013 thanks that helps alot Share this post Link to post Share on other sites
moparmanheat1 1 Posted May 8, 2013 Hello GC, I've done a few multi-colored jobs. I create registration marks on the different layers then I use clear masking. I just did a back glass on a buddies truck and I used Rapid Tac 1. It turned out perfect. Have a good one ! Share this post Link to post Share on other sites
egobuster1 9 Posted May 8, 2013 yeah i just apply registration marks to all the layers and i use clear application tape for my multi color decals. as for application ive done them both wet and dry and had good results both ways. Share this post Link to post Share on other sites
gcextreme 475 Posted May 13, 2013 Ive tried wet..and im either doing it wrong or it just sucks....cant get it to dry and stay... Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted May 13, 2013 u Ive tried wet..and im either doing it wrong or it just sucks....cant get it to dry and stay... If it is on glass try rapid tac two and also if you are using intermediate vinyl but on premium vinyl or in hot weather it may dry too quick . Share this post Link to post Share on other sites
gcextreme 475 Posted May 13, 2013 I will try that....my issue is its not drying! I put on a two layerd decal on my topper window glass yesterday eve, did it wet, and its still not dry today...ive squeegeed the hell out of it!...its not drying or sticking to the glass... Share this post Link to post Share on other sites
gcextreme 475 Posted May 13, 2013 Heres my project...its not drying and sticking! <img src="http://i1311.photobucket.com/albums/s675/gc_extreme/VINYL/20130513_120919_zpsf1d844e0.jpg" </img> Share this post Link to post Share on other sites
LPWash 75 Posted May 13, 2013 Is the red/yellow vinyl on good and just the app tape that's bubbled? Hard to tell from the pic. Share this post Link to post Share on other sites
gcextreme 475 Posted May 13, 2013 Yeah its on good, the app tape is like that from me trying to peel it off and the vinyl isnt staying on th glass... And this clear tape just sucks period...its the Rtape... Share this post Link to post Share on other sites
mopar691 281 Posted May 13, 2013 a wet application with clear tape will never dry. Use paper tape only for wet installs. IMO clear tape is all around garbage. I have never been happy with it and refuse to use it. 1 Share this post Link to post Share on other sites
gcextreme 475 Posted May 13, 2013 Im begining to think its garbage too, but using the nonclear stuff i cant see my registration marks for crap... I read a write up on doing wet apps and it said to use clear... For one i just know i need more practice applying vinyl.....but my graphtec is cutting great tho!! I have alot of requests for simple solid one color stuff and im making some money on those... I just want to practice and get good with 2+ LAYERS.. Share this post Link to post Share on other sites
mopar691 281 Posted May 13, 2013 make a light table, use a window, etc. But I suggest getting away from clear tape. If going on anything with more complex curves clear tape does not conform like paper either. Share this post Link to post Share on other sites
mabscotthandyman 1,410 Posted May 14, 2013 Paper tape is all I use. Glass is a little harder to apply to.First clean very well then clean with alcahol before applying . Usaly on glass I will apply let set a while then come back and spray the (paper tape ) with app fluid let set then remove tape . A side note keep paper towels handy to dry off while you squeege to keep it from seeping back under the tape and vinyl . Share this post Link to post Share on other sites
211 Grafix 24 Posted May 14, 2013 I agree with MOPAR 691. Throw that clear app tape out! I also use a light table or reg. marks on larger semi lettering ect. I have applied wet or dry. If I apply wet I use very little spray, I don't know if that's right, but it works for me. I also spray the app tape to help loosen up a bit before pulling off. Share this post Link to post Share on other sites
jessehop 6 Posted May 14, 2013 when i did my lettering yesterday glenn i had the same problem with the clear tape.. iam going back to the paper tape once i have a order to get n\more supplies.. my factors for yesterday for the long process of removing the tape was it was not drying but then it was a little to cool out too maybe not warm enough. but im still wanting to go back to paper tape Share this post Link to post Share on other sites
egobuster1 9 Posted May 14, 2013 I've used clear and paper tape and i always seem to have better luck with clear tape and if your selling decals the customers can see the decal with the clear tape but I've had a lot of issues trying to find that perfect tape for my oracal 651 vinyl. i got the Rtape paper and it just doesn't seem that great to me and i got the greenstar clear tape and its been so so Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted May 14, 2013 Try Main Perfect Tear medium tack paper tape. . That is all I have used for several years. And I started with R-tape Conform 4050.RLA .medium tack, I prefer Main much better. Share this post Link to post Share on other sites
gcextreme 475 Posted May 14, 2013 Try Main Perfect Tear medium tack paper tape. . That is all I have used for several years. And I started with R-tape Conform 4050.RLA .medium tack, I prefer Main much better. Where do u get that at? Link? Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted May 14, 2013 I have purchased my Main Transfer Tape from this EBAY seller for years. Jack Ripper. I use a lot of tape so I purchase the 48" log and they slit it FREE to your specs. But they have a lot of other sizes. They are located in Michigan, So, I get next day shipping if ordered before noon. I am a state away. Great service http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200923872485 Share this post Link to post Share on other sites
