tlzimmerman 11 Posted April 20, 2010 Decided to take all the videos I have made so far and put them in one place. I am going to redo the first too in the next couple weeks hopefully, and am open to more ideas on videos. I am putting this same post in a couple forums, not sure if one of the admins wants to make it a sticky or not. The first two will be remade soon so they don't use the jerky wink program. They will all require a player plugin to play .wmv files (windows media player normally) All these videos use inkscape because its my favorite program to design in, plus its free and open source so EVERYONE has access to it. Simple Vectorize in Inkscape http://www.thomasandjayme.net/flashpresentation/2ndtry.htm Thumbsup Lesson 1 - Simple manual trace in Inkscape http://www.doublezdecals.com/images/forumposts/VectorChallenge01/VectorChallenge.htm Lesson 2 - Stroke, Path, and fill basics http://www.doublezdecals.com/images/forumposts/lesson2/TeachemtofishLesson2wmv.html Lesson 3 - Simple From Scratch Design - No food or drink Sign http://www.doublezdecals.com/images/forumposts/lesson3/TeachemtofishLesson3wmv.html Lesson 4 - Text how to - Vectorize and Manipulate http://www.doublezdecals.com/images/forumposts/lesson4/lesson4.html Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 20, 2010 thanks a bunch. I'm sure it will be used alot.. and I will defiantely send people here. Share this post Link to post Share on other sites
dinki 3 Posted April 30, 2010 These are great! I hope you can post more ... Thanks for spending so much time putting these together. Share this post Link to post Share on other sites
nickl333 0 Posted January 18, 2011 Hello, I wonder if anyone could help or point me in the right direction, (i hope this is the right catogary) I have come across 2 problems with inkscape, I have a sticker cutter which requires vector images. (signblazer,signcut 2) the issue is with the spiral tool, i want to maqk the lines thiker but i can't find where to do it? and the last thig is (flatten the image) my cutter program will not recognise images that are multi layerd and in photoshop you flattern. for instance i mde a tree then filled it and it would not recognise it as 1 image. could you tell me how to make this one vectorised image that my other program would recognise. I think the problem is the lines. i creaed a patern with the pencil tool witha thick stroke and then filled with the paint fill tool and it had a very thin white line between the stoke and the fill, (something that my sticker cutter program would cut as 2 seperate pieces where i need it to recognise it as 1 pece. i need sort of a flattern tool if you undrstand. i want to be able to make a shape and (bazer tool) and then fill (pint tub) and it be 1 piece flatterned (if you will) and ready to cut. best regards and much respect (lucydugdale@googlemail.com) Share this post Link to post Share on other sites
nickl333 0 Posted January 22, 2011 thank you very much for your tutorials!! I am having slight problems with: Simple Vectorize in Inkscape (your 1st vid) i can do the trace of bitmap, and then be left with the vector image, however the part where you get rid of the line over the eyes using the path;diffrence tool i can't do. you say you hold down shift and select the origional traced vector but what is the othe thing you select? when i try and do this all that happens is it deletes the box i have just drawn. i do hope ive not lost you thanks again for the great vids Lucy. Share this post Link to post Share on other sites
lawman12 3 Posted April 21, 2011 The first link gives a 404 error Share this post Link to post Share on other sites
BamBam82 1 Posted August 21, 2011 Hi, I think you mentioned in the second video that you had images we could download to practice on. Is there any way you can direct me to where they are because I can't find them. Thanks! Share this post Link to post Share on other sites
joescornhole 0 Posted August 24, 2011 First link is no longer active. Other than that thanks for the vids. Very informative. Share this post Link to post Share on other sites
Jimmybjj 0 Posted February 3, 2012 does anybody have updated links? they all seem to be dead Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 3, 2012 this might help you out http://support.uscutter.com/index.php?/Knowledgebase/Article/View/147/9/how-to-create-vector-images-with-inkscape Share this post Link to post Share on other sites
busterbay 326 Posted August 7, 2013 None of these links seem to work, even the knowledge support link for inkscape is broken. Share this post Link to post Share on other sites
slice&dice 2,450 Posted August 7, 2013 Google is your friend. http://bit.ly/13NhU8D Share this post Link to post Share on other sites
busterbay 326 Posted August 7, 2013 Yep figured it out Select photo / object Then from the menu bar: PATH --> Trace Bitmap Share this post Link to post Share on other sites
TheKid 29 Posted January 27, 2014 The OP of this thread must have changed the links. This is a deadend STICKY. Please bury it with respect. Share this post Link to post Share on other sites
