Dragonduster
Members-
Everything posted by Dragonduster
when i send the design (its a rectangle with the corners rounded) to cut it will always finish like in the picture (red circle) and the line should cut where the green line goes, i did a test cut (from the machine) and it made the square and diamond shape cut fine, i checked the design and its fine, i tried with the pen and plain paper and the drawing was correct, i checked with cutting pressure with 800g, 400g, 200g, 45g and all finish the same, i have always used redsail but tried liyu with the same end i dont know what may cause this since the design is fine, doing a test cut is fine and everything i try ends fine, but when i start to cut the job, it ends like that. i have the SC uscutter machine and using SignBlazer v6.0.5
- 5 replies
- finish circle
- sc uscutter
(and 1 more)
Tagged with:
machine wont cut as desired
Dragonduster replied to Dragonduster's topic in SC Series Vinyl Cutter Discussions
my cutter is a SC UScutter and i read that i should use liyu drivers (before it was redsail) with signblazer. the exposed blade is fine as i checked that from the start and doing the cut tests i barely saw the marks in the backing paper. "add a little over cut in your cutting software." i havent made this but i think i should try this too.- 5 replies
- finish circle
- sc uscutter
(and 1 more)
Tagged with:
I bought this action tac from uscutter a Long time ago and i want to use it with a screen protector of my smartphone so i can place it correctly but since i bought it more than 5 years ago, will it still work the same?
i was making a decal in 2 parts, the first one was cut fine, but in the second part, when i try to cut it, it will make 2 diagonal lines making that part useless and it doesnt cut it like i want. i have used the drivers of RedSail RS1120C (been using this all the time) and Copam CP2500 but i still get that line cut (attaching image of the cut) i am attaching the file here too to see if someone can figure out whats wrong with it (i made the size smaller so i can upload it, but i am cutting it to the size around 64 x 35". I am using a uscutter SC serie cutter. Untitled-2.eps
HELP!! cutter makes 2 diagonal cuts that mess my vinyl
Dragonduster replied to Dragonduster's topic in SignBlazer
mmmmmmmm......... i had to cut the image in half, doing the tile didn't work -
nop, didn't work, what can i do to make more ground? -
mmmmmm.... i had a little cable for the static but i need a bigger cable i guess, i will try again once i connect another cable to ground it. -
i will help my GF with a luminous sign and i was wondering if normal vinyl would do it or do i need translucent vinyl? Will be black (most of it), red and green (like android green) attached is an image as to what i mean with luminous (like those)
should i use translucent black too? or with solid is ok? since its black
how does it look with light from behind? i want to know how it looks using black translucent black vinyl on a iluminated sign
paper that looks like frosted vinyl (or etched glass)
Dragonduster posted a topic in Other Materials
Here where i work, a guy was installing a paper that looks like frosted glass, its not vinyl (doesnt feel like vinyl when i touch it) and as far as i know, the price of the vinyl here is around $7.50 a meter, the frosted vinyl is very expensive compared to that and the guy installing it said it was paper, anyone knows about it? Or is there a cheaper vinyl brand that sells frosted vinyl? Thanks. -
How to make big jobs with a 24" cutter?
Dragonduster posted a topic in Business Practices, Sales and Pricing, etc.
as the tittle says, lets say i have a job of a decal with 30" x 90", how do you make them? i was told to leave 1" between the cuts and overlap them but i dont know about this method. -
Dragonduster replied to Dragonduster's topic in Business Practices, Sales and Pricing, etc.
Thanks a lot, that link helped me. -
I use ..... forgot name, it's the one that doesn't has support anymore and is free, with element in the name. I have the cd of corel 3 or 5, forgot it, came with the plotter. I wanted to cut and ship them so im not the one installing and the customers would have trouble installing them. -
Graphtec ce300-60 for $650 is good price?
Dragonduster posted a topic in GraphTec Cutting Plotter Discussion
a friend's boss is selling a graphtec ce300-60 for $650, semi new. i have a uscutter one already of 32" but dont know if i should get this one or save for a ce600-60, i read the ce300-60 is very old now. is it a good price? should i buy it or wait? -
u can remove it and use it somewhere else?
Dragonduster replied to Dragonduster's topic in GraphTec Cutting Plotter Discussion
they wanted $700 for it, but said could lower to $650, i dont know if its the mk2 version. i will ask and see. -
Can I use the 651 for wrapping my car? Change its color. If not, why not? Which one should I use? How long will it last? My car is always on direct sunlight and we have had up to 50c (sun burn ur skin, even air sometimes)
Mmmm.... tnx, those wrap vinyl sure are expensive =/
i used oracal 641 clear on a phone, it got scratched very fast while my GF put the phone inside her purse =\ Is there any vinyl scratch resistant or something like that? i would love if there would be one like Skinomi's ones lol
Pricing for 40" x 14" + vectorizing
I know someone (not really a friend, just went together to a language class) that wants this image (attached) in vinil. how much should i charge for this image (in 6 colors) and the vectorizing? i used a tool here and it says $155 but thats kinda high price i think. -
$165 + vectorizing? or with vectorizing incluided? -
My Pricing Calculator
Dragonduster replied to huntrjo's topic in Business Practices, Sales and Pricing, etc.
i think if u put 1 in the QTY with 5H and 37W, complex 8, 1 color, u would need to put a 1 in 36" since its bigger than normal ones, that way it will give your $35 + 15 since its bigger than 36", if you use the 23", you will get a +14, if you put a 1 in both 23" and 36", that means you have 2 decals, that would mean 2 in QTY. you need to fill the column A to E (mandatory), then if its a specialty vinil, or the decal is smaller than 6x6 or you use fluorecence color, add a 1 below it, if its bigger than 23" but smaller than 36", add a 1 below the 23", if its bigger than 36" add a +1 below it, its easy to understand =) Please correct me if i am wrong- 40 replies
- Pricing
- Calculator
(and 4 more)
Tagged with:
the tittle says it all, just the vinyl, non cut vinyl, as there has been a thread about how long it will last WITH the app tape already. Thank you.
