Days Won
4
Everything posted by sleeveofwizzard
Pricing help on large wood sign please
sleeveofwizzard posted a topic in Business Practices, Sales and Pricing, etc.
I am getting the hang of vinyl pricing but I have no clue what to charge for a wood sign with installation. It will be 1 sheet of thick plywood with to 3 sandwiched 2 x 4s on each end to hold it up. I will be digging and cementing it into the ground. I estimate the construction will take me 3 hours and the install around 2 hours. Materials maybe around $60 -$70 so the only thing I came up with is around $450 for labor and materials, what do you guys think? -
LaserPoint USB port
sleeveofwizzard replied to sleeveofwizzard's topic in LaserPoint Cutting Plotter Support Requests
Awesome thanks for the tip! -
LaserPoint USB port
Lueman, What do you mean by reset? -
I think it was a version issue, I was able to open it with Flexi, Adobe Illustrator and Inkscape but not with Signblazer. I changes the settings so that it is importable with Signblazer now. After you select the file choose the "use full postscript interpreter" button. Here is a link to download Inkscape, it is a great program for vector graphics. I use it to create, edit, and vectorize images then send them to the cutting software. http://support.uscutter.com/index.php?/Knowledgebase/Article/View/192/42/01-inkscape-graphic-design-software
Qe60 cutter turns on but doesn't do anything
sleeveofwizzard replied to prettybird's topic in GraphTec Cutting Plotter Support Requests
http://www.signwarehouse.com/tech-support/pdfs/VEX_Qe06_151.pdf Here is a link to the manual. It has a lot of good info in it. follow the setup steps one by one and you will be able to determine if it is working. (registers media is loaded, cutter head is movable by touch controls, can perform test cut.) Once those things are confirmed you can move onto attempting to figure out the cutting software and getting that to work because the wrong settings and file can prevent it from working. Good luck -
Got it, THANKS! Looks like there are some good ones in there.
LaserPoint USB port
Well the last tech I spoke with didn't know much about the board and he had me order it from the website. The other two techs I spoke with yesterday were pretty knowledgeable and nice. I'll give her a try when it comes in and hope for the best. My plan to purchase a second cutter is going to have to happen sooner than I was planning. Downtime is expensive! -
LaserPoint USB port
Thats not good news! I am worried about what the original problem was that caused the short. the wiring all looks intact and the old USB I/O board doesn't even look broken. The new main board I ordered should arrive on Monday but I was a little worried about just plugging it in if there is another issue that could short it out. You said I will need to reuse my UV-prom because it is not included with the new board I purchased. Are these available to purchase somewhere since you think mine is probably bad? is there a way to test it? -
I business I follow on Facebook American Specialty Ammo just purchased a hydro dip setup. It looks awesome and I want one. Check out this video of the guy dipping his hand in it.
sleeveofwizzard replied to sleeveofwizzard's topic in Business Practices, Sales and Pricing, etc.
That job sounds fun! I went low on my original quote because I don't know better and because it is a subcontract through an associate of mine. I rebid the sign at $650 and should hear back this week from the customer. -
LaserPoint USB port
Ok as far as I and US cutter support can tell the board is bad. Just ordered the replacement and now I wait. -
OMG!!! HHEEEELLLLPPP!!!!
sleeveofwizzard replied to Rmedoc's topic in USCutter Equipment Feedback or Suggestions
I just moved into an office suite I share with two other people. I warned them my cutter is noisy but they were not concerned I haven't asked them if they regret it, probably won't ask either ha ha. -
LaserPoint USB port
I'm going to borrow a multimeter from my friend and test what I can in the morning. I'm thinking I am just going to have to buy a new board but I am terrified that there is another issue as well. I can imagine that worst happening, maybe some wiring is at fault and will short the new board as well! -
Hey guys, I haven't spent much time playing with my print transfer materials I bought awhile back because I really haven't had much luck when trying. For the dark shirts, I have done a couple of the opaque transfers. The color is great but the edges around the image are white and look bad. I tried to trim as close as possible to the image I printed (by hand) but there was still white after I transfered it. For the JPSS I realized it is really only good for white shirts because the color of the shirt will show through the image but I have a similar problem with it as well. I did a shirt with sisser easy weed text and a small portrait of patrick swayze next to it. I removed the background from the image but there is still some sharp edges at the bottom where his shirt was. it just doesn't look right to me. is there a way to feather the edges or soften it?
JPSS and 3G Opaque HELP!!!
sleeveofwizzard replied to sleeveofwizzard's topic in T-Shirts and/ or Garments
Wow that sandwich looks great! Thanks for the tips I really appreciate it. I'll give it a try tomorrow and post my results. -
LaserPoint USB port
I cleaned it a little and it's definitely dirty. I see what your saying, kind of a water pattern there, I really don't know how it could have ever gotten wet while I have had it. Even my kids would have to work pretty hard to get water on this board with the way the cutter is enclosed lol. I would love to buy the board if that will fix it, but with starting this new business I am really tapped out. Haven't been able to sell anything yet because of non stop issues! -
LaserPoint USB port
Update, now my cutter won't cut using the serial port either. I don't know what happened but I hooked it up to the old desktop with the serial cable and can't get it to do anything. I opened up the cutter and found some corrosion on the main board, oh crap! There are two spots that look like they are damaged but I don't know much about PCBs. Any ideas on this guys, is it repairable or do I need to replace the board? -
Laserpoint Driver for Sign Blazer Elements
sleeveofwizzard replied to ldietzen's topic in SignBlazer
I am messing with this same deal right now. I installed the patched software and tried the RedSail driver but can't get it to cut. I guess I'll just go back to the trial version. -
I hear ya. I feel very limited as to what I can use the jpss and opaque transfers for. I did a white shirt a while back with a picture that had a white background and it came out great! The picture was a drawing of a boy standing next to a tree. I adjusted the color so that everything was softer and a lot of the little detail disappeared. Softened the edges and perfecto! With old Patrick Swayze here, his arms and chest are dark colors and I didn't do anything to them. -
I think I removed the background with Photoshop on this one. I have that, Corel x3 and inkscape that I use for images. -
LaserPoint USB port
Lueman, I was considering having someone look at my cutter to try and track down the issue but it would probably end up costing me a pretty penny. I think some of the parts for the LP are still available, off the top of your head do you have any idea what might be shorted out on our cutters? -
LaserPoint USB port
Yeah I don't think that it is Sign Blazer either, I was just mentioning how when I said the name SignBlazer when asking for support I became a red headed step child. I will most likely pick up an adapter because my desktop is a dinosaur of a computer. -
LaserPoint USB port
P.S. I requested assistance through UScutter and was told they no longer support Signblazer and I need to purchase Sure Cuts Alot. I wish I had a different program to test and see if Signblazer was the issue or not. -
LaserPoint USB port
here are screen shot of the sing blazer ports. I am no longer at the my office and since there is no USB devices plugged in to my laptop no ports show up in device manager. I did the same thing! when the USB port broke I switched to the serial port which worked great. Now the problem is I do not have a serial port on my laptop that I am now using for vinyl. Like you were saying my computer does not beep when the cutter is plugged into it but it does recognize it in Sign Blazer and device manager. I did try it on an old desktop I took to my office today to test it. When I plug it in to the desktop, the USB does make the connection sound but the same issue with no cutting. I did get it to work through the serial cable though. -
LaserPoint USB port
ok, yes Mz Skeeter I went through all the steps a few times for the setup. I have triple checked the settings and even tried different com port numbers and different usb ports. Lueman, I did not solder this. I bought a replacement from a forum member. thanks for the tip, this is what I got from it. Under ports (COM &LPT) there is = USB Serial Port (COM8) The wieird thing is that if the cutter is on and connected it shows up under cutter setup in Sign Blazer as = Blazer.COM8: - USB Serial Port It just won't cut! In sign blazer it shows the cut progress as if the cutter was working and does not show any communication errors.
