cod543 0 Posted October 27, 2013 I recently bought my SC cutter plotter, and first the black cartridge was off its hinges so i put all 3 wheels back on the tracks. So thats not a problem anymore. Yet, now the blade holder doesnt come down enough to hit the vinyl, meaning that theres still space between the vinyl and the blade. the blade is out enough however. I dont know if i got a small blade holder or if there is a malfunction anybody have any ideas on how to fix this problem? Share this post Link to post Share on other sites
Rodger 527 Posted October 27, 2013 Check and see if the holder is all the way down in it's clamp . If not tight , sometimes they push up some . Share this post Link to post Share on other sites
cod543 0 Posted October 27, 2013 the clamp is the thing next to the cartridge right ? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 27, 2013 Make sure those wheels are firmly down in the track. Here is the repair guide: as a double check. Yes, blade holder clamp is next to the carrriage head. http://support.uscutter.com/index.php?/Knowledgebase/Article/View/253/60/05-sc-series-carriage-off-track-repair-guide Share this post Link to post Share on other sites
cod543 0 Posted October 27, 2013 I actually got all three wheels in the track last night. so it works smoothly now. its just the blade has space between the vinyl Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted October 27, 2013 this is how you set your blade correctly: To start with, you should set your blade depth correctly, by taking the blade holder out of the machine, and firmly cut across a piece of scrap vinyl, you will be cutting. You should only be cutting the vinyl and barely a mark on wax paper backing, Adjust blade to get there, Then put the blade holder back in machine, and use the force of the machine to get there, same results, only cutting the vinyl and barely a mark in wax paper backing. Share this post Link to post Share on other sites
cod543 0 Posted October 27, 2013 My blade is in correctly, less than the width of a credit card. My problem is: the blade doesnt reach the vinyl. Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 27, 2013 The blade holder sits within the clamp (there's a slot to accept the blade holder). In other words, it isn't designed to rest with the flange of the blade holder sitting on top of the clamp assembly, but rather nestled inside of it. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted October 27, 2013 is the blade holder dropping when the cut command is given? Share this post Link to post Share on other sites
BannerJohn 1,324 Posted October 27, 2013 The blade holder sits within the clamp (there's a slot to accept the blade holder).In other words, it isn't designed to rest with the flange of the blade holder sitting on top of the clamp assembly, but rather nestled inside of it. He wouldn't be the first person to make that mistake,either. Share this post Link to post Share on other sites
karkess 28 Posted October 27, 2013 HA! I did the exact same thing when I got my cutter a couple weeks ago. I bet your blade holder looks like this right now... Grab the blade holder and pull up...I bet it slides right out. This is how it should look.... Hope this helps... 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 27, 2013 Great illustrations for what I tried to indicate, karkess. Those close-up pix are exactly what the doctor ordered. Gold star for you. Share this post Link to post Share on other sites
karkess 28 Posted October 27, 2013 LOL! Took me a bit to figure why my machine wasn't working. Can I wear the star on my forehead? Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted October 27, 2013 HA! I did the exact same thing when I got my cutter a couple weeks ago. I bet your blade holder looks like this right now... Grab the blade holder and pull up...I bet it slides right out. This is how it should look.... Hope this helps... My blade holder looks just like your first pic can't get it in the slot where it is supposed to be. but have used my cutter for a couple of years now. if i put it in the grove can't get anything under the blade at all mine is a MH. Share this post Link to post Share on other sites
karkess 28 Posted October 27, 2013 ^^^ MH uses a different blade holder. COD is using the SC which is the same cutter I have. Share this post Link to post Share on other sites
