action 0 Posted November 15, 2016 I have a titan 15 in plotter with basic vinyl master program.....I was told I cannot scan to this program.. without upgrading.....but, I was told I can scan to windows like, Paint, and export the scanned product to the vinyl master program, manipulate the text there and send to the plotter..... I do not have a scanner and do not want to buy one if this will not work.....Has anybody done this Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted November 15, 2016 You need to be able to get the raster artwork into the program one way or another and then trace it (vectorize). Whether you use a flatbed scanner or have clients email you their artwork depends on what works for you. But if you have physical artwork you wish to copy and trace for cutting you will need a scanner or a digital camera and a steady hand. Quote Share this post Link to post Share on other sites
Sue2 920 Posted November 15, 2016 10 minutes ago, VinylMaster said: You need to be able to get the raster artwork into the program one way or another and then trace it (vectorize). Whether you use a flatbed scanner or have clients email you their artwork depends on what works for you. But if you have physical artwork you wish to copy and trace for cutting you will need a scanner or a digital camera and a steady hand. Digital cameras are hard to hold still enough to get a good sharp photo of artwork. If you don't want to buy a scanner, check out a local print/copy shop. Many of the more expensive laser printer/copiers we use can scan to flash drive. Even our HP 8600 inkjet office printer has the ability to scan to a flash drive as PDF or JPG in various resolutions....might be all you need. Sue2 Quote Share this post Link to post Share on other sites
action 0 Posted November 16, 2016 22 hours ago, action said: I have a titan 15 in plotter with basic vinyl master program.....I was told I cannot scan to this program.. without upgrading.....but, I was told I can scan to windows like, Paint, and export the scanned product to the vinyl master program, manipulate the text there and send to the plotter..... I do not have a scanner and do not want to buy one if this will not work.....Has anybody done this The BASIC VINYL MASTER program will not scan... according to tech support unless I upgrade.....I have to indirectly get the art work into the computer via another program then export to vinyl master...any ideas what other programs I can use in windows 7 Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted November 16, 2016 What exactly are you meaning when you say "scan"? If you truly mean scan, you need hardware, software alone doesn't scan. Quote Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 16, 2016 Action --- the VM Basic indeed has the function to import from a dedicated scanner (or three-in-one printer) attached to the computer via USB. IMAGES menu - Aquire (sic) Image (the spelling of Acquire is wrong, but the feature is there) The information you got from tech support is incorrect, and if you talk to them again, tell those guys that it works just fine, and to at least fix their spelling mistake! Quote Share this post Link to post Share on other sites
action 0 Posted November 22, 2016 thank you slice and dice, i will check that out, my old system gerber worked the same way...scan artwork and acquire image and there it was to work with. I found the tech people have given me more than once wrong info Quote Share this post Link to post Share on other sites
