MadHatterGraphix 1,258 Posted May 6, 2016 I was approached by someone I make t-shirts for about cutting craft foam with my cutter for some of their projects. As a nice guy as I am I said I do not know for sure. So instead of me going and trying this out and probably screwing up my cutter I came here to ask if It's possible and if someone ever did this on their Graphtec? Share this post Link to post Share on other sites
Macon Innovations 228 Posted May 6, 2016 What kind of thickness? Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted May 6, 2016 What kind of thickness? 5mm to 6mm and 1/6" that hat I got from the customer. I guess it ranges. Share this post Link to post Share on other sites
Jburns 239 Posted May 6, 2016 5mm to 6mm and 1/6" that hat I got from the customer. I guess it ranges. I would say that a Flatbed cutter with vacuum hold down would be best for that. ex Graphtec FC4500 seres. Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted May 6, 2016 I would say that a Flatbed cutter with vacuum hold down would be best for that. ex Graphtec FC4500 seres. What about using a sticky cutting mat like for a silhouette or Cricut? Share this post Link to post Share on other sites
Jburns 239 Posted May 6, 2016 I think you are right - a cutting mat would be needed if you are cutting thru and should work on the graphtec.-- perhaps if you keep the foam inside the rollers? and the pinch wheels on the cutting mat that could work out cool. but for the depth- the Blade Holder : CB15N- that uses the 1.5mm diameter blade might work better. Share this post Link to post Share on other sites
Jburns 239 Posted May 6, 2016 I would ask for a sample and see how it goes Share this post Link to post Share on other sites
mb20music 760 Posted May 7, 2016 5mm to 6mm and 1/6" that hat I got from the customer. I guess it ranges. Pretty thick, don't think you can do it , maybe 2mm max... Share this post Link to post Share on other sites
busterbay 326 Posted May 7, 2016 I'm sure this is die cut by the mfg. Just have your finger on the off switch if things go south. 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 7, 2016 This guy did hand cut foam. Great skills on an older post.. Foam made me think of it...... http://forum.uscutter.com/index.php?/topic/36709-hand-carved-foam/?hl=tiki Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted May 7, 2016 I think that foam is thicker than what I'm talking about, have you ever seen those foam craft letters for kids? they are all different colors? Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 7, 2016 I have seen instructions to cut with a hot wire. Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted May 7, 2016 its 1/16 of an inch thick I just got a sheet of it sorry about the quality of picture. Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted May 7, 2016 Just a quick update I told my client no I dont want to take a chance ruining my cutter. Share this post Link to post Share on other sites
pshawny 410 Posted May 7, 2016 I have an Accucut GrandeMark 2 die cutter that should be able to handle that, but custom dies are needed for each project. So far I've only used it to cut 30mil magnet. 1 Share this post Link to post Share on other sites
Primal Decals 621 Posted May 7, 2016 I know a cricut will cut it for sure,My girlfriend uses hers all the time for that. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 7, 2016 This guy did hand cut foam. Great skills on an older post.. Foam made me think of it...... http://forum.uscutter.com/index.php?/topic/36709-hand-carved-foam/?hl=tiki dear god - you have a memory like a western digital hard drive Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 7, 2016 dear god - you have a memory like a western digital hard drive And it's no wonder my brain does not got to sleep...... 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted May 7, 2016 And it's no wonder my brain does not got to sleep...... if you start hearing a constant clicking - get to the dr quickly Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 7, 2016 if you start hearing a constant clicking - get to the dr quickly I meant not go to sleep.. Clicking like an external hard drive? , I will. I thought he did great work, would love to see more.. He has his own niche' with that. Share this post Link to post Share on other sites
