iamandy 20 Posted July 3, 2014 Is there a safe way to remove vinyl from a vehicle? Share this post Link to post Share on other sites
Dawn's Design 403 Posted July 3, 2014 I use a little heat. Then orange peel to remove the adhesive . Share this post Link to post Share on other sites
iamandy 20 Posted July 3, 2014 Hmm, good tip! Thanks! Share this post Link to post Share on other sites
FrznFire07 217 Posted July 3, 2014 hair dryers are you best friend Share this post Link to post Share on other sites
busterbay 326 Posted July 4, 2014 Magic eraser will also remove the adhesive --- ancient Chinese secret Share this post Link to post Share on other sites
Snapper 30 Posted July 5, 2014 Park it in the Sun use plastic razor blades to lift the edge and pull. If you have nothing better Rubbing Alcohol will take the adhesive residue off. Share this post Link to post Share on other sites
jarrotto 78 Posted July 5, 2014 Rapid Remover lives up to it's name. Just be careful using it on some plastics. Share this post Link to post Share on other sites
LPWash 75 Posted July 8, 2014 Heat gun on low setting works the best. Work the edges a little longer. Not long enough and it won't come off. Too long and it gums up too much where it just gets gummy and breaks off. Once you get the timing down, it will pull the vinyl AND the adhesive off. It took us a 16' box truck to figure out the best method. Tried everything on both sides and it wasn't until half way on the final backside where I figured it out and then we were pulling off two foot long sections at a clip, adhesive included. Good luck. Share this post Link to post Share on other sites
OWJones 1,981 Posted July 8, 2014 I keep meaning to try these two products, but haven't taken the time yet: Vinyl Off Ghost Off Share this post Link to post Share on other sites
