Redneck Printing 0 Posted January 5, 2014 I just got my us cutter yesterday and the guy showed my it works, but I get it home and I can not get it to cut my design, it only cuts a straight line over and over. Please help. Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 6, 2014 The design-cutting feature is an optional accessory that costs extra. What cutter did you buy? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 6, 2014 wrong driver? Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 6, 2014 Did it come with any software? A cutter isn't like a printer that will just plug and play. What design are you trying to cut? We need more info to be able to help you. Share this post Link to post Share on other sites
lecxer 0 Posted March 2, 2014 I have the same problem I have a mh 871 cutter and I using sure cuts a lot pro but only cut straight line over and over but no my design I need help Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 2, 2014 I have the same problem I have a mh 871 cutter and I using sure cuts a lot pro but only cut straight line over and over but no my design I need help Did you activate Sure Cuts A Lot? You must, or it will cut through the designs. If that is not it, then more info is needed. If on a USB, put it on a serial cable, serial card, or a Keyspan Adapter,,, (that is the brand name). Read under MH cutter threads, these problems have been written a zillion times on here. And so have the answers. Share this post Link to post Share on other sites
