ajkelly 1 Posted October 31, 2013 Using Scalpro With A Mh871. Everything Worked Fine In The Beginning Now It Does This. Only On Small Script And Shapes. That's Arial Font. I've Adjusted Offset From 0 To 1.00 In .05 Increments. I've Had To 2Xs Cut Everything The Past Week. Help!!! Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 31, 2013 Your grit rollers are not tight. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 31, 2013 ^^^^what he said^^^^ There are allen head set screws you can tighten to eliminate the slippage. Share this post Link to post Share on other sites
ajkelly 1 Posted October 31, 2013 Thank You! Will Try That As Soon As I Get Home Share this post Link to post Share on other sites
ajkelly 1 Posted October 31, 2013 Tried ToTighten Them... They're Already SupeR Tight. What Else Can You Suggest? Share this post Link to post Share on other sites
jaybyrd 3,770 Posted October 31, 2013 Make sure the carriage that goes left to right has all the wheels on track. There is something mechanically slipping with your cutter. 1 Share this post Link to post Share on other sites
maddog 12 Posted November 1, 2013 Also if that is one of those HUGE rolls of paper make sure to unroll and have some hanging freely as the cutter will have a hard time unrolling that big heavy roll of paper. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 1, 2013 definate movement somewhere, since you have checked tthe tightness of the grit rollers, make sure the wheels of the carriage are on track, then see if there is slop in the rollers indicating a loose belt. also worth checking the carriage arm for cracks etc. you are using the back hole in the carriage arm right? Share this post Link to post Share on other sites
ajkelly 1 Posted November 1, 2013 No, NoT A Huge Roll Of Paper. Just A Sheet. Rollers On Carriag Are On Track. Checked That First Thing WHen It Started that. There Is Only 1 Hole In The Carriage Arm If Youre Talking ABout Where The BLade Holder Goes. Otherwise Im Unsure Whst You Mean Since Im Only 2 Months Into This. Also Rollers Do Not Look Like They Are Slipping. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 1, 2013 so your arm doesn't have 2 places for the holder like this one? http://www.uscutter.com/US-Cutter-MH-Carriage-Arm Share this post Link to post Share on other sites
ajkelly 1 Posted November 1, 2013 No. Mines Mh871-Mk2. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 1, 2013 still looks to me like slippage in the vertical axis - like slop in the belt - or if I rememer correctly there was someone that had problems with the bearing on the rod to the grit rollers had slipped out - maybe have to call tech support when they get in to diagnose furthers Share this post Link to post Share on other sites
ajkelly 1 Posted November 1, 2013 Will Do. Thank You! Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 2, 2013 What's with the Capitalized Lettering Of Every Word? There's a screw loose somewhere. Share this post Link to post Share on other sites
ajkelly 1 Posted November 2, 2013 Thank Y'all ForAll The Help. I Fou.d It On My Own. Live Customer Support Wouldnt Respond And Making A Call While Sitting At The Cutter In The Greenswamp Is Dang Near Impossible. The Problem Was The Long Gold Screw With The Lock Washer And Nut On The Front Right Side Of The Carriage Behind The Black Square Cover WS Extremely Loose. Tighten It An Now My Star Is Perfect. 1 Share this post Link to post Share on other sites
ajkelly 1 Posted November 2, 2013 Its My Dang Droid Doing It. It Stsrted Capn Every Letter After Update. Share this post Link to post Share on other sites
ajkelly 1 Posted November 2, 2013 Thats Down Right Beautiful There After Seeing That Funky Shaped Stuff All Week! Share this post Link to post Share on other sites
slice&dice 2,450 Posted November 2, 2013 Ah-Ha, happy happy happy!!! Share this post Link to post Share on other sites
skarekrow 1,842 Posted November 2, 2013 Its My Dang Droid Doing It. It Stsrted Capn Every Letter After Update. Agreed... Beware the "Updates". Personally, I have to have ~my own~ darn good reason to "update". I've have plenty of issues after allowing one. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 2, 2013 glad you figured it out - now we have another fix on the books we can search! 1 Share this post Link to post Share on other sites
