joker 618 Posted August 19, 2013 After reading that info Mine dont do that. What mine does is it leaves a little spot like the node has to be edited but the nodes are good. When weeding it likes to hang up every now and then. Share this post Link to post Share on other sites
busterbay 326 Posted August 19, 2013 Gosh I started something... heck same things happens on another forum I frequent. OK I adjusted the blade & pressure - didn't cut a thing Adjusted blade back out still low pressure - didn't cut a thing USCutter recommends 100g set it to that put blade back to starting position and it cut with tags Adjusted offset - Ahhh now we has less tags Adjusted Overcut ( Sure Cuts A Lot 3 ) has this option - less tags Adjusted Overcut again - even less tags Adjusted offset one more time and BINGO.. I will do a more complicated item tomorrow. Thanks for all the suggestions !!! It appears it was the overcut & offset 1 Share this post Link to post Share on other sites
security802 686 Posted August 19, 2013 Thanks for link Monkey, I had the jaggies and have been cutting at 100 to 200 speed. Did a 10x10 x and it was perfect. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted August 19, 2013 just make sure your offset is adjusted correctly or you will get rounded squares or little fins on the corners Share this post Link to post Share on other sites
busterbay 326 Posted August 19, 2013 just make sure your offset is adjusted correctly or you will get rounded squares or little fins on the corners I will make some squares and block letters tomorrow and test. The new Sculpt has overcut if your machine is supported found that on their website. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted August 19, 2013 nice new addition . . . they had better be careful on some of the stuff that is copywrited to other companies - they may end up like they did with cricut. Lawsuit almost did them in till the usc rescue Share this post Link to post Share on other sites
joker 618 Posted August 19, 2013 What should the offset setting be for the SC cutter in signblazer.. Not sure on this. My cuts are pretty clean except for real tight corners. Share this post Link to post Share on other sites
busterbay 326 Posted August 19, 2013 Cricut has a nice racket going... I don't know anything about the lawsuit but Cricut has some of the burden to bear for leaving their system vulnerable. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted August 19, 2013 I believe Cricut saw it differently, more like hacked. Share this post Link to post Share on other sites
busterbay 326 Posted August 19, 2013 I believe Cricut saw it differently, more like hacked. Appears so... If I were Cricut I would have done the same. However if I were Craft Edge I also would have done the same also. I think this forum will be fun once I learn how not to cut vinyl the way I am currently doing it. 1 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted August 19, 2013 Things can get interesting around here and usually end up way off topic but if there is an answer to be found this is the place to find it. 1 Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted August 19, 2013 What should the offset setting be for the SC cutter in signblazer.. Not sure on this. My cuts are pretty clean except for real tight corners.offset depends on the blade and can even change as a blade wears 1 Share this post Link to post Share on other sites
Monkey 252 Posted August 19, 2013 I will make some squares and block letters tomorrow and test. The new Sculpt has overcut if your machine is supported found that on their website. Few things I found to make SCALP run smoother was take it off "Auto" and select right port based on what your device manager says its on Change cut mode from what you see is what you get to origin Share this post Link to post Share on other sites
busterbay 326 Posted August 20, 2013 Thanks, Monkey I will give that a try. Last night I put in a 60 degree blade and it cut the very detailed items without issue. Share this post Link to post Share on other sites
