mountaindr3wz 0 Posted June 9, 2012 Hi all, it seems ive run into a problem while making a business hour sign. I converted object to paths and then combined all and then saved as an .eps file. When imported into sign cut, it ends up as the picture shown( 2nd picture). I have attached the .svg file and .eps file for the sign if anyone wants to take a shot at it. If you solve it, will you also tell me what you did please. It seems that this is the first time I ran into this problem. Thank you buisnesshours.eps businesshours.svg Share this post Link to post Share on other sites
mark-s 1,126 Posted June 9, 2012 The bar below hours is not complete, it`s just one horizontal line with a short down turn. Not a complete bar. mark-s Share this post Link to post Share on other sites
mountaindr3wz 0 Posted June 9, 2012 I made it a thin box now, but it still doesnt show up complete in S.C. Share this post Link to post Share on other sites
banditt2129 25 Posted June 9, 2012 Have you selected all then combined? Share this post Link to post Share on other sites
mountaindr3wz 0 Posted June 9, 2012 When I selected all and combined I got this: businesshours1.svg Share this post Link to post Share on other sites
Dr12volt1338 116 Posted June 10, 2012 I downloaded the .eps and brought it into Flexi and it opens fine...... Share this post Link to post Share on other sites
mountaindr3wz 0 Posted June 10, 2012 I downloaded the .eps and brought it into Flexi and it opens fine...... if possible, could you post the .eps file. For some reason, it still doesnt want to work out for me. Share this post Link to post Share on other sites
markvvq 14 Posted June 11, 2012 See if either one of these work for you try this.ai TRY THIS.eps Share this post Link to post Share on other sites
Dr12volt1338 116 Posted June 11, 2012 You can try it but as I said it is the exact file you uploaded... Sounds like maybe a glitch in your software somewhere.... buisnesshours.eps Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted June 11, 2012 I downloaded the .eps and brought it into Flexi and it opens fine...... Did you put the file on wire frame, when you opened it? I imported the above file into Flexi, put it on wireframe and I got the same results as Mark-s the box was not completed.,,,,,. Just a line with a down turn in it. And the .eps file that you reposted is the same way, when put on wire frame..... uncomplete line with a turn down line Share this post Link to post Share on other sites
mountaindr3wz 0 Posted June 12, 2012 somehow it still doesnt work? Share this post Link to post Share on other sites
Dr12volt1338 116 Posted June 12, 2012 I didn't put it in wire frame but in the Production manager it looks as though it will cut fine. Share this post Link to post Share on other sites
mountaindr3wz 0 Posted June 13, 2012 I finally solved the problem! Solution: For some reason, using inkscape's "object to path" for the outer frame and bar were not making it show up when imported to signcut. Using "stroke to path" made it work! Share this post Link to post Share on other sites
