Days Won
15
Everything posted by VinylMaster
VinylMaster Cut "Nothing to Cut" error
VinylMaster replied to iwbc's topic in VinylMaster CUT, LTR, PRO & DSR
We see you have found that by switching on or off what is traced in the color bar deals with alpha channel bitmaps. Since this technique/process can be unclear to new users we will modify the Vectorizer to better handle images with transparencies. Thank you for you input.- 12 replies
- 3
- vectorizer
- nothing to cut
(and 1 more)
Tagged with:
That feature has now been reinstated and will be available in the upcoming update. Thanks for letting us know.
Yes we have that and as soon as a programmer can take a look at it they'll get back to you via tickets.
Support has responded to this, and a DXF issue has since been identified and corrected. These changes and others will be applied to the next update due out shortly.
Vinylmaster Cut will not import DXF file
VinylMaster replied to a topic in VinylMaster CUT, LTR, PRO & DSR
Yes, this issue has since been identified and corrected. These changes and others will be applied to the next update due out shortly. -
calibration all of a sudden is off
Please refer to the FAQ which answers most of these questions: My artwork is cutting at the Wrong Size? -
Save the artwork as .ai in Illustrator and then click the File (menu) > Import > File in VinylMaster and select the saved file.
There is cumulative update being put together for USCutter which will be automated so long as you are on the Internet. There is also an auto-update for Xpt that will be released later in the year. However, you must have a 2015 build or more recent for this to be fully automated. Many 2014 builds and earlier do not automatically-update, these are semi-automated. See the Help (menu) > About to see which build date you have. If 2014 or earlier, please lodge a ticket with your PSN and if there is an update for your software it will be sent to you.
It's all automated...
Thanks for the tip. We'll have it looked at and sorted for the next update.
Cutting a triangular shape on my already cut designs
Lodge a ticket with a copy of the file that does this and a photo of the issue. http://future.support -
Please visit this page for licensing: Licenses and Activation
Can you please upload this to http://future.support so a programmer can take a look at it.
If you have Pro you can use Step & Repeat or Tile Array to have infinite control on spacing across the horizontal and vertical axis. However, if you wish to adjust the spacing after sending a multiple of a single object you can set Tight Packing on or off from the Settings (menu) in the Vinyl Spooler.
Can you please PM us as we cannot see a ticket relating to this issue. Also, the issue does not relate to the level of the software so upgrading will not resolve it. We need to see the file. Thanks
In that case lodge a ticket at http://future.support and attach the DXF file so a programmer can take a look at it.
If you can export in AI V8 this will resolve that issue.
Can you explain what you are trying to do with an example and which level of the software you have because Tile Array is only in Ltr and above and cutting tiles only in Pro and Xpt.
OEM is currently undergoing a series of tests before being updated.
Trouble seperating a design
VinylMaster replied to Macon Innovations's topic in VinylMaster CUT, LTR, PRO & DSR
Upload the artwork to support so they can see what you are trying to do. If they are separate Power Clips you can save them as .vLogos (one at a time) or copy and paste each to a new document and save it off... -
Lodge a ticket at http://future.support with your PSN and there should be an update as auto-rotate was replaced some time ago. The current version doesn't do this.
The artwork is all saved when you save the document. You can also copy and paste these into another document and save as well. To learn more about Power Clips and how they work click on the Help (menu) > Help Topics > Color and Fills > Power Clips -
VinylMaster Cut 4.0 - Duplicate Logo
VinylMaster replied to CollegeKevin's topic in VinylMaster CUT, LTR, PRO & DSR
You can set the number (qty.) when you send the artwork to the Cutter - see Quantity in line with Job name. -
LaserpointII/Vinylmaster cut software downloads
From your ticket you have a Mac. Future Corporation software will run on a Mac by using Boot Camp to run Windows on the Mac. If you're unsure how to do this, please click here for details: http://www.apple.com/support/bootcamp/- 2 replies
- laserpoint ii
- vinylmaster cut software
(and 2 more)
Tagged with:
You create a Cut Document... click on the Help (menu) > Help Topics > Cutting and Plotting > Cutfile Documents
