AFKnut 1 Posted May 25, 2022 I was wondering if it is possible to import color samples into vinyl master pro? I use carbon fiber a lot and would love it if I could use the color samples when mocking up work! I attached a pic of what I want to upload. Any help appreciated! Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 25, 2022 I have Vinyl Master demo, but can't you look in the color library, FIND COLOR? Many vinyl color samples from the actual vendors there. Quote Share this post Link to post Share on other sites
AFKnut 1 Posted May 25, 2022 I have looked through all the samples, no carbon fiber Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 25, 2022 Did you look by brand? What brand is it? Quote Share this post Link to post Share on other sites
AFKnut 1 Posted May 25, 2022 vvivid vinyl. Not even in the list. But I looked through all listings and seen no carbon fiber at all Quote Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 25, 2022 Why would it matter about seeing the texture? Cutters are made to handle whatever you throw into them, and so long as you have the colors defined in the cut screen, you can choose the one(s) you intend to cut. This is not printing, where the overall design needs to reflect exactly the final output, as a matter of specification. Use green as your color choice in the design program, and load carbon vinyl into the machine, done. If a customer wants to see what the material actually will look like, show them the actual vinyl material (a swatch sample). 1 Quote Share this post Link to post Share on other sites
haumana 1,220 Posted May 25, 2022 So carbon fiber is more a pattern than it is a color, though I hear what you're saying about getting mock-ups to clients. The difficulty that you'd run into that, is that in order to see the carbon fiber pattern, there are different shade of green involved in order to visual the pattern and texture. Quote Share this post Link to post Share on other sites
AFKnut 1 Posted May 26, 2022 S&D, the texture matters because when I am designing something a solid green does not look anything like carbon, so after I cut it thinking it will look good it looks like shit. Many times I have just reversed colors or layouts, but sure would be nice to see what it will look like before wasting my vinyl haumana, ya I wasn't sure how it would look, but even if it just repeated the swatch I uploaded that would suffice. Its prob not possible, but something they should add! 1 Quote Share this post Link to post Share on other sites
AFKnut 1 Posted May 26, 2022 Some things look good in carbon, others do not. And until you cut it you dont really know. So would just be nice to see the actual design before cutting is all. I am really surprised this has not come up to them before! Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted May 26, 2022 2 hours ago, AFKnut said: S&D, the texture matters because when I am designing something a solid green does not look anything like carbon, so after I cut it thinking it will look good it looks like shit. Many times I have just reversed colors or layouts, but sure would be nice to see what it will look like before wasting my vinyl haumana, ya I wasn't sure how it would look, but even if it just repeated the swatch I uploaded that would suffice. Its prob not possible, but something they should add! I don't know my way around VM very well but possibly you could do a Clip of the sample. They probably call it something different maybe trap. I'm an Adobe person so I'm only fluent in AI terms. The trick will be getting the carbon texture to be size accurate. 1 Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted May 26, 2022 I went and found a free vector of carbon fiber and was able to change the color and use it for fill as a clipping Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted May 26, 2022 I mostly use Inkscape for my design, but I did something like this once with a plaid pattern. Took a photo of the pattern, pulled it into the design, sized it then clipped it with the design. Not as convenient as just changing colors, but it worked well. Quote Share this post Link to post Share on other sites
AFKnut 1 Posted May 26, 2022 Thanks guys ..Ill try both of those! Quote Share this post Link to post Share on other sites
haumana 1,220 Posted May 26, 2022 I agree with Wild - the scaling of the carbon pattern within the design might be difficult to get on point. But I totally get that some customers just cannot envision what something will look like. The struggle is real when it comes to some customers. Quote Share this post Link to post Share on other sites
