deadtree02 0 Posted February 22 Hello, If this is in the wrong area please let me know so I can correct in the future. I am knew to all things vinyl. My school has bought a GCC expert II. I have been tasked with understanding how it operates and I feel comfortable with how I have done so far. My boss was wondering if they make a cutter that can do 2 cuts at once. We have a laser cutter that both engraves and cuts during the same process. I know vinyl cutters are not the same and I am pretty sure this is not possible. Basically my boss would like to cut just the vinyl and cut through the vinyl and paper during the same cut. I told her this could not be done with our current machine... I am just double checking to see if they make a machine that does this Thank you in advance Share this post Link to post Share on other sites
slice&dice 2,235 Posted February 22 No. The one thing you want to avoid doing is damaging the white nylon 'cutting strip' by having the blade run into it (gouge it) by going through the backing paper of the vinyl. Your boss needs to rethink her goals. 3 Share this post Link to post Share on other sites
Cal 393 Posted February 22 Welcome aboard deadtree, glad to have you here. What is your boss trying to achieve by doing this? Avoiding the expense of the transfer tape? Slice gave you the correct answer to your question, but if we knew the goal there might be some suggestion for getting there. What type of work is planned for the cutter? 1 Share this post Link to post Share on other sites
Dakotagrafx 7,148 Posted February 22 the graphtec fc series has a special feature for this that will not damage the cut strip but will cost you as much as several of the gcc plotters 2 Share this post Link to post Share on other sites
MZ SKEETER 4,487 Posted February 22 I agree, starting with the Graphtec FC8000 on up, You can do this. They have a channel on the cutter, and a 2nd position for the blade holder, that cuts over that channel, so no damage to cutting strip. These cutters also have 8 different conditions that can be set for cutting. You can check for used deals on Ebay, Craigslist, or Fbook Marketplace. 3 Share this post Link to post Share on other sites
Wildgoose 4,104 Posted February 22 That type of cutting is often called Flex-cut or Kiss-Cut. Typically the first cut around a printed object (termed a "contour cut") is done normal then a second cut (usually a little farther out from the original contour cut line) with the FLex-Cut/Kiss-Cut setting cuts the vinyl and periodically pushes on down harder and cuts the carrier sheet as well then pops back up to continue cutting just the vinyl and so on. The decals can later be broken free of the carrier with light finger pressure. This process won't work with regular cut gaphics that need a tranfer paper but does work with printed graphics that have a fairly simple countor shape. If you cut all the way through the carrier sheet all heck will break loose and you lose the integrity of the sheet as it's trying to feed the vinyl back and forth in the pinch rollers. Summa makes a flat-bed cutter than has vacume hold down that can probably cut all the way but I have never used one. 2 Share this post Link to post Share on other sites
