badun 3 Posted August 4, 2020 A friend asked me to cut some 1/32" rubber sheet into roughly 3"x5" pieces. I have a PrismCut P20. Any recommendations on the blade type, speed, pressure, etc? I have extra material with which to experiment but I'd rather not waste it if someone has some guidance for me. Thanks! Share this post Link to post Share on other sites
darcshadow 1,626 Posted August 4, 2020 Simple rectangle pieces? I'd suggest a piece of scrap wood or a Cutting mat, straight edge, and a utility knife. 1 Share this post Link to post Share on other sites
badun 3 Posted August 4, 2020 No, there are curves and cutouts around the posts as seen in the image. I should have said it's a gasket for an electronic device. The gasket goes to the edge of the case. Don't ask me what it is because he's trying to make me guess and I haven't figured it out yet! I have the SVG of the gasket and it is clean, I just offered to find out for him if it can be readily cut by machine. 1 Share this post Link to post Share on other sites
darcshadow 1,626 Posted August 4, 2020 I'm not finding anything about the max cutting depth, but for reference most vinyl is around 4 mils. 1/32" is 31 mils, so I doubt any vinyl cutter would be able to cut this material. Looking at the photo you posted, I see no reason why a simple rectangle wouldn't work, there's no need for a gasket around the screw holes. The only thing I see is the whole thing might need to be a bit larger to give slightly more surface area for the gasket to make contact with especially around those holes. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted August 4, 2020 3 hours ago, badun said: No, there are curves and cutouts around the posts as seen in the image. I should have said it's a gasket for an electronic device. The gasket goes to the edge of the case. Don't ask me what it is because he's trying to make me guess and I haven't figured it out yet! I have the SVG of the gasket and it is clean, I just offered to find out for him if it can be readily cut by machine. https://jasonmccallister.wordpress.com/ Share this post Link to post Share on other sites
Go-C Graphics 856 Posted August 5, 2020 I've cut gasket material on my laser but never on my plotter. 1 Share this post Link to post Share on other sites
jeffreyequalitybrooks 0 Posted November 25, 2020 im curious about this too -- i'd love to be able to cut thin silicone sheets as well, im wondering if you found something to work out for you? Share this post Link to post Share on other sites
haumana 1,220 Posted November 26, 2020 If you're willing to try it on your cutter - just use a carrier mat, and you'll probably need to do multiple passes. How many does he need to get done? Share this post Link to post Share on other sites
