Signs and Designs 17 Posted March 6, 2016 I can not remember where I went and turned on. Cutter (Graphtec Ce5000-60) return to start. When cutting, the cutter will finish cutting and then return the vinyl back to the beginning, where is it I go to change the setting of the cutter or VM, to cut the graphic and stop right there on the end and not return all the way back to the beginning. Thanks in advance Bob ( I hope I explained it right..) Quote Share this post Link to post Share on other sites
storm2313 25 Posted March 6, 2016 What?? I'm sorry I don't understand. Quote Share this post Link to post Share on other sites
lizzylou 11 Posted March 6, 2016 Choose FILE> SEND TO CUT > Choose General Tab at top >Select Cutter Model> Properties> About Half way down the page on the right is Cutting Options> Check ADVANCE AFTER PLOT Quote Share this post Link to post Share on other sites
Signs and Designs 17 Posted March 7, 2016 Thank you Quote Share this post Link to post Share on other sites
Signs and Designs 17 Posted March 8, 2016 I checked vinyl master and advance after plot is not ticked, after every job it still goes back to the beginning of the vinyl and just not stay at the end so I can just advance a little bit and cut off. anything else I am missing? Quote Share this post Link to post Share on other sites
Macon Innovations 228 Posted March 8, 2016 I think you want it checked or it will return to origin. Quote Share this post Link to post Share on other sites
ign 5 0 Posted March 8, 2016 Restore to factory settings haha. That's what I do whenever I get dumb issues. just remember or take pictures of your condition settings and you are good to go. If you do decide to go this route, it is very simple. You hold some buttons while you turn the machine on, Just do a search on this forum. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted March 8, 2016 I checked vinyl master and advance after plot is not ticked, after every job it still goes back to the beginning of the vinyl and just not stay at the end so I can just advance a little bit and cut off. anything else I am missing? You want to check that box for advanced after plot, That's what your looking for. It should be checked. Quote Share this post Link to post Share on other sites
skarekrow 1,842 Posted March 8, 2016 I realize the miscommunication going on here with the check mark in the box but, must add; Since moving my cutter (Graphtec CE5000-60) and Activated copy of Vinylmaster Pro over to my laptop with Windows 8, doesn't matter if the box is checked or unchecked, cutter still returns to origin after every cut. A little frustrating. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted March 8, 2016 Request a new driver from http://future.support with an explanation of this issue. Quote Share this post Link to post Share on other sites
skarekrow 1,842 Posted March 8, 2016 Thank you... will do. Quote Share this post Link to post Share on other sites
Signs and Designs 17 Posted March 9, 2016 Requested Thank you Quote Share this post Link to post Share on other sites
Guest OffSign.cz Posted April 11, 2018 Hi, have the same problem. Advanced after plot is checked but vinyl after cutting go back to the begining. Do you have any solution? or information from support? THX Quote Share this post Link to post Share on other sites
