Primal Decals 621 Posted May 13, 2017 4 hours ago, slice&dice said: It's not "wrong" PrimalDecals, it just didn't seem to add any value (there's no substantial reduction in size, which is the primary benefit of zip, or when combining several files into one compact archive). A while ago, there was a SignBlazer download floating around that was contained within a zip suitcase, and it had an SBE installer as well as a small PATCH program to eliminate the start-up screens. That patch was kinda cool -- it had an evil-looking gargoyle appear when it ran, and yeah, it seemed like it would probably infect your computer with a deadly virus!! Anyway, no worries, mate, and anyone needing SBE can get your file, or go to the USCUTTER 'secret' download. The first 7 posts in this thread illustrate how SignBlazer and USCUTTER have parted ways (as they needed to, under the circumstances), and we should be grateful that they even still provide the secret download! ok.thanks bud.I understand lol.. Share this post Link to post Share on other sites
guinter810 0 Posted January 30, 2019 I have signblazer elements on 3 computers and have been using it for 3-4 years now. Connected to R32 Rseries plotter (have 2 of these) For some reason on all 3 computers and both machines the computer will not find the cutter. Usually under Setup, then Redsail RS720c or any it will show up as USB 3 and bunch of wording. If I unplug the USB and plug it in, it makes noises like the computer sees it. I even went and manually deleted all stored USB off the computer and let it reinstall. I did use the link above you guys posted, even went and reinstalled the driver (MH) and still nothing. Any help would be great. I also own a SUMMA and can get it to cut with all 3 computers Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 30, 2019 7 minutes ago, guinter810 said: I have signblazer elements on 3 computers and have been using it for 3-4 years now. Connected to R32 Rseries plotter (have 2 of these) For some reason on all 3 computers and both machines the computer will not find the cutter. Usually under Setup, then Redsail RS720c or any it will show up as USB 3 and bunch of wording. If I unplug the USB and plug it in, it makes noises like the computer sees it. I even went and manually deleted all stored USB off the computer and let it reinstall. I did use the link above you guys posted, even went and reinstalled the driver (MH) and still nothing. Any help would be great. I also own a SUMMA and can get it to cut with all 3 computers did you install the usb chipset driver for the redsail plotter first? is that the driver you are referring to? like the MH series it uses a flaky serial to usb chipset built into the cutter that has to have it's own drivers for the plotter to connect Share this post Link to post Share on other sites
guinter810 0 Posted January 30, 2019 51 minutes ago, Dakotagrafx said: did you install the usb chipset driver for the redsail plotter first? is that the driver you are referring to? like the MH series it uses a flaky serial to usb chipset built into the cutter that has to have it's own drivers for the plotter to connect I think that is the issue. When I go under Device and printers it shows that there is an issue with the machine. I click troubleshoot and states that it is missing the driver. where do I find the USB chipset driver? Weird Ive use the same computer for years and now it seems like it lost the driver out of no where Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 30, 2019 is that for the redsail or the mh? (this is for usb- the serial does not require the separate driver) not sure which one the redsail uses - we can look up the ftdi for the mh if that is what you have Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 30, 2019 you can find that driver at redsailcnc Downloads 1 Share this post Link to post Share on other sites
guinter810 0 Posted January 30, 2019 Its the R-series II by vinyl express which usually cuts from Signblazer elements as a Redsail. Am using a USB connection Share this post Link to post Share on other sites
guinter810 0 Posted January 30, 2019 41 minutes ago, MZ SKEETER said: you can find that driver at redsailcnc Downloads The driver files will not open from their site. I sent them a email to see if they could send me the redsail driver Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 30, 2019 This is the one that USCutter offers -- perhaps it's a solution? USB emulation driver Also, this is the v7.0.0 SBE -- no nag screens. SBE "secret' download archive Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 30, 2019 5000 posts -- WooHoo!!!!! 2 Share this post Link to post Share on other sites
guinter810 0 Posted January 30, 2019 24 minutes ago, slice&dice said: This is the one that USCutter offers -- perhaps it's a solution? http://www.uscuttersupport.com/downloads/Drivers/cdm20828_setup_windows.exe Also, this is the v7.0.0 SBE -- no nag screens. http://www.uscuttersupport.com/downloads/Software/SignBlazer/signblazer_setup.exe These both show that the link is dead. Part of the issue I am having with signblazer elements. I did reinstall it with a link from the 1st page of this tread from 2017 and that worked but driver didnt install Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 30, 2019 Just now, guinter810 said: These both show that the link is dead. Part of the issue I am having with signblazer elements. I did reinstall it with a link from the 1st page of this tread from 2017 and that worked but driver didnt install usb drivers specific to your plotter are not part of any cutting program - those have to be installed first Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 30, 2019 26 minutes ago, slice&dice said: 5000 posts -- WooHoo!!!!! congrats on the milestone Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 30, 2019 47 minutes ago, guinter810 said: The driver files will not open from their site. I sent them a email to see if they could send me the redsail driver sent PM. 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 30, 2019 1 hour ago, guinter810 said: These both show that the link is dead. Part of the issue I am having with signblazer elements. I did reinstall it with a link from the 1st page of this tread from 2017 and that worked but driver didnt install The URL's are correct --- try those again. (I fixed the links in the post, if you click on them now, they're OK) Share this post Link to post Share on other sites
guinter810 0 Posted January 30, 2019 @slice&dice Thank you. I have the driver installed, having issues now with communication. (have used SB for several years) wont find my USB . Downloaded a trial of another program and can get the machine to cut vinyl . So now I am trying to figure out why it will not find the USB in the program. Signwarehouse instructions show that everything on my end computer wise and driver wise is correct for USB connection Share this post Link to post Share on other sites
haumana 1,220 Posted January 30, 2019 25 minutes ago, guinter810 said: @slice&dice Thank you. I have the driver installed, having issues now with communication. (have used SB for several years) wont find my USB . Downloaded a trial of another program and can get the machine to cut vinyl . So now I am trying to figure out why it will not find the USB in the program. Signwarehouse instructions show that everything on my end computer wise and driver wise is correct for USB connection Go to your windows device manager and look to see what port Windows assigned to your cutter, then go into SB and make sure it matches. Do not use Auto. Share this post Link to post Share on other sites
