Xpanic 0 Posted July 23, 2013 Hi all, new in the forum. I have the following issue: When cutting a contour with the laserpoint the cutter fails producing also like a "mirror cut" on the right side of the plotter. You can find a attached image that better explains the problem. Thank you in advance Share this post Link to post Share on other sites
slice&dice 2,451 Posted July 23, 2013 Why are you using contour cut for this? Share this post Link to post Share on other sites
Xpanic 0 Posted July 23, 2013 Because is a colored sticker printed on a mutoh plotter Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 23, 2013 Are you just trying to cut around the outside? If so why all the cut lines through the design area. Share this post Link to post Share on other sites
Xpanic 0 Posted July 23, 2013 The file is a simple illustrator vector, if cutted in "normal mode" all works fine. The problems exists only using the countour cut function (simple/advanced) in signcut. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 23, 2013 Do you really have a MH 721 Refine vinyl cutter, that UScutter sells, as you stated at the top of this thread....? Or a Laserpoint2 which is made by Liyu? Which really is a contour cutting vinyl cutter. As MH 721 vinyl cutters are not a laser pointer and do not do contour cutting. . Big difference between MH 721 and a Laserpointer2. The MH721 that UScutter sells, does not even have a laser on it. Share this post Link to post Share on other sites
Xpanic 0 Posted July 23, 2013 @Mz Skeeter: I really have a MH721 with laserpoint. Problem FIXED: I've putted the laser a little bit "far" from the first registration mark, at about 1cm, instead of just near. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 23, 2013 Obviously,, not purchased at UScutter...... Share this post Link to post Share on other sites
Xpanic 0 Posted July 23, 2013 And that changes something in the world? I had a problem, asked other people for a solution, finded a solution, shared the solution for the community benefit. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted July 23, 2013 And that changes something in the world? I had a problem, asked other people for a solution, finded a solution, shared the solution for the community benefit. No, not at all. It just took me longer to try and figure out what you really had....because USCutter does not sell Refines with a laser point. Many, many people come on here and post in the wrong threads. New people sometimes don't even know what vinyl cutter they have. And if you notice, YOU posted it under USCUTTER REFINE VINYL CUTTER< when it is NOT. It is a competitor's machine, and there is a category for that. Which would have made more sense. Share this post Link to post Share on other sites
Xpanic 0 Posted July 23, 2013 I have purchased a cutter, on the label I can read MH721, drivers from USCutter, configured as USCutter Refine MH721.... anyway is not so important, I'm really satisfied with this machine. The most important thing is the solution of a problem, a problem not strictly related with a specific machine model. I hope it can be usefull for other people. Share this post Link to post Share on other sites
TheKid 29 Posted January 29, 2014 Why doesn't quote work? Xpanic, where did you find that cutter for sale. I'm interested. PM me if you wish. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 29, 2014 Why doesn't quote work? Xpanic, where did you find that cutter for sale. I'm interested. PM me if you wish. @ TheKid, just curious, are you just interested in a MH cutter that contour cuts? If so, you can purchase, Flexistarter 10 and turn your MH into a contour cutter.. The program is in the software It works for most any vinyl cutter. . Does not use a Laser. measures registration marks with the blade in the middle of the registration mark and records in the cutting software. Can be had for under $130 on Ebay..... Recommended to be use with a serial cable. Purchase the All cutter version. It is also sold on UScutter website. but higher priced. Share this post Link to post Share on other sites
kkeeble 64 Posted May 11, 2017 MZ SKEETER...are you saying that if you have an MH series cutter you can run software to contour cut around a printed image even tho there is no laser on the MH? Share this post Link to post Share on other sites
darcshadow 1,627 Posted May 11, 2017 Any cutter can technically contour cut, the trick is getting everything lined up so that the contour cut is exactly where you want. If you have the patience and ability to take good measurements, you could contour cut without any special software, again, just a matter of lining everything up both in the software and hardware. 1 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted May 11, 2017 With software that will allow it you can get a standard cutter to do a contour cut within reason. All the feedback that I read even on the laser pointer machines is that they end up using the blade to align the cutter rather than the laser due to problems with the offset distance of the laser. IMO the laser is a sales gimmick although the LP2 seems to be a superior machine in general. True contour cut machines have an optical eye that reads the registration marks and will cut accurately. 1 Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted May 12, 2017 11 hours ago, kkeeble said: MZ SKEETER...are you saying that if you have an MH series cutter you can run software to contour cut around a printed image even tho there is no laser on the MH? Yes, Flexistarter has it's own contour cutting program built into it.The software uses the location of the blade in the center of the registration marks., then it is recorded in the software. The software has interactive buttons to jog the cutter between the registration marks. My versions of Flexistarter 8.6v2 and 10 have it....Flexistarter is getting hard to find, as it has gone to cloud... If you get it, I would suggest the all cutter version,,which is exactly that includes hundreds of vinyl cutters. Some vinyl cutter distributors include or sell versions that only have their vinyl cutters on it...Maybe only Pcut version, Liyu,version, I saw several youtube videos showing how to use Flexistarter to contour cut printed images..Some of the instructors are hard to understand do to language barriers. But they show it slow enough that you can see. Share this post Link to post Share on other sites
