nutmonkey 0 Posted November 3, 2008 I am using FlexiSign Pro v8.1 and as you can see in the first image I have a 3 Layer design, problem is when I put it in production manager the lines from the "V" will cut into my Mugen decal (you can see this in the second image) how can I correct this? I have tried welding it but it's not doing what I want....Thanks in advance guys/gals... Share this post Link to post Share on other sites
nonabelle 5 Posted November 3, 2008 hey where's u image Share this post Link to post Share on other sites
nutmonkey 0 Posted November 3, 2008 I was having trouble posting the image b/c i was linking ".bmp" files so I had to change to ".jpg"... sorry Share this post Link to post Share on other sites
JoeDirt 5 Posted November 3, 2008 seperate/ungroup it all then select and copy/paste and cut what you want. then you can cut the white v and rest of the pieces how you want. Share this post Link to post Share on other sites
ms_sign 5 Posted November 3, 2008 Make one of the whites a different color and then cut by color. I do this all the time. Jon Share this post Link to post Share on other sites
firemalt 10 Posted November 3, 2008 I personally would "ungroup" the image. Highlight the red portion, and "copy" it, then delete it. Highlight all of the white portions, and "weld" them together. And finally "paste" back the red portion. It should fall right back into place if you haven't moved anything. Share this post Link to post Share on other sites
nutmonkey 0 Posted November 3, 2008 Thanks guys for the help.... Jon I actually did what you suggested before I posted the question (I used grey as my optional color) then cut it by color, I just thought there was a better way to do it and figured I would ask. Firemalt by the way I wanna call you fruitloop so bad (I guess cause of your avatar) anyway if I do this your way I will have a funny looking V until I lay the red on top right? I may give it a try this way just b/c I never have and it will be a 2 layer sticker instead of 3 layers. Thanks again everyone certainly gave me something to think about.... Share this post Link to post Share on other sites
Rodger 527 Posted November 3, 2008 Firemalt by the way I wanna call you fruitloop so bad (I guess cause of your avatar) .... Now that is funny stuff . ESPECIALLY coming from " nutmonkey" So , did you actually call him " FruitLoop " or just say you wanted to ;D ;D Share this post Link to post Share on other sites
nutmonkey 0 Posted November 3, 2008 No no no I am not calling him a fruitloop I just want to b/c of the avatar lmao Share this post Link to post Share on other sites
firemalt 10 Posted November 3, 2008 Months ago, knucklehead(bk2designs) edited his sig, calling me out as a fruitloop... so I thought it was only fitting to add fruitloops as my avatar. Share this post Link to post Share on other sites
UPTOWN 0 Posted November 20, 2008 seperate the layered images. with the japanese lettering seperated from CIVIC, create an outline and then seperate that as well, this will be your red part. cut them all non layered. Lay down the white CIVIC layer the White Japanese lettering on top of the red outline Now lay the 2 merged white/red decals ontop of the CIVIC. Share this post Link to post Share on other sites
