JoeDirt 5 Posted October 4, 2008 Hi, How do I remove the center, white cuts, I want the flames to go thru so it would be solid. Thanks!!!!!! EZF464.eps EZF464.eps Share this post Link to post Share on other sites
C Lewis 6 Posted October 4, 2008 I have it for you. having probs uploading it.... Whats your email? i will send it to ya Share this post Link to post Share on other sites
C Lewis 6 Posted October 4, 2008 i just opened it in illustrator, select the whole object and merge in pathfinder...... 123 Share this post Link to post Share on other sites
JoeDirt 5 Posted October 4, 2008 alright i will try that, but seems there must be a way in flexi. Thanks for the info. Share this post Link to post Share on other sites
dinki 3 Posted October 9, 2008 alright i will try that, but seems there must be a way in flexi. I am interested in knowing how to do this in Flexi as well. Does anyone have any insight? I've tried removing nodes but it just made a mess of things. Share this post Link to post Share on other sites
tmobil 0 Posted October 24, 2008 Could it be to uncompound and then weld. maybe Share this post Link to post Share on other sites
tmobil 0 Posted October 24, 2008 nope, that won't work. But, this seems to work. Make a contour cut, 0 offset. Separate the contour cut and deleteor move the original design. Uncompound the contour cut. Delete the unwanted cuts. Should leave you with what I think you are looking for. Contour cut= Effects menu, contour cut Separate contour= Effects menu, separate contour cut Uncompound= Arrange menu, compound, uncompound Share this post Link to post Share on other sites
Jack Beck 2 Posted November 8, 2008 Here is another way to do this in Flexi Make a solid block bigger than the graphic and place on top. Select all...than goto effects..combine..seperate overlap. now select and delete the pieces you dont need. Select the rest and goto effects.. combine.. weld Jack Share this post Link to post Share on other sites
JoeDirt 5 Posted November 9, 2008 Thanks all I will have to try that in the shop tomorrow thanks again! I will let you know. Share this post Link to post Share on other sites
jimmy1234 1 Posted November 14, 2008 Open image you wish to correct Select image Check the wireframe box - Fill Stroke/Editor Use the cleaver tool (Click and hold drag across any one line, release) - Slide out menu under Select Point Tool Use the Select Within Tool (Select what you want removed, delete) - Right Click Menu That works on this image, not sure about others....and Im sure there is a better way. Jim tribal.eps tribal.eps Share this post Link to post Share on other sites
