LegoMyEggrollz 1 Posted November 5, 2024 I see that there is a new line of MH cutters, i was curious if anyone has bought either of these 3 models and what is your opinion on them vs the MH 721-MK2/871. I was curious if these have a true USB Chipset or is it the same? i mostly cut car decals, and HTV i don't do contour cutting. I currently own a MH 721 MK2. Share this post Link to post Share on other sites
slice&dice 2,470 Posted November 6, 2024 (edited) Are you intending to get the larger size cutter? (30" instead of 24"?) If not, then what you are working with now should be OK to keep running, no real need for a replacement. Having said that, it would be interesting to get reviews or comments regarding the new line of MH units. Nobody has come in with their 2-cents yet, but if there's a member with problem or confusion or request for assistance, we'll be here. ]]]]]]]]]]]]]]] Note: USCUTTER shows the MH100-34 (30)" being unavailable currently. Strange to see that, honestly, since they just introduced it. Edited November 6, 2024 by slice&dice These new MH100 34" cutters are "Sold Out" Share this post Link to post Share on other sites
LegoMyEggrollz 1 Posted November 6, 2024 Thanks for responding! I was bouncing between the 28" or the 53", I need a new vinyl cutter since my 721 died on me and was having alot of issues with drivers on windows 11, so i did initially purchase a Titan 3 but i canceled that order, since i decided i did not need the contour cutting feature nor the servo motor, i called the sales rep and asked if it had the true usb chip set like the Titan series and she confirmed it did have it, Share this post Link to post Share on other sites
darcshadow 1,641 Posted November 7, 2024 Could you post a photo of your stand/roller issues. Looking at the photos of the stand online I'm not clear on your problem and am curious to see it. The pinch roller, double check that it's full seated in the slides. But also, you should only really need 2 rollers. Share this post Link to post Share on other sites
darcshadow 1,641 Posted November 7, 2024 Interesting, it almost looks as if the cutter is sitting on the stand backwards. If I remember right the old MH's the cutting head had the blade on the other side, so the problem you're running into would not have happened. Could be a case of they redesigned cutter but not the stand. Share this post Link to post Share on other sites
LegoMyEggrollz 1 Posted November 8, 2024 interesting, thanks alot for the detailed post, I just purchased the 53" M200, a day before your reply,, we shall see if i run into the same issues you have, I will keep this thread updated on my findings Share this post Link to post Share on other sites
Wildgoose 4,200 Posted November 27, 2024 As an update, I've been discussing the issues with USCutter staff/support. I'll post something after this is resolved but I do have to say the support so far has been good. Hangfire, excellent feedback and information! It is really helpful to hear these kinds of things and your work-arounds. The new MH being out now I am sure there will be a lot of new buyers that hopefully do a little research and get a step ahead thanks to your efforts. Share this post Link to post Share on other sites
slice&dice 2,470 Posted November 28, 2024 I think that USCUTTER is working with the Chinese manufacturer to address several issues on these MH updated versions. That would explain the "Sold Out" situation, which is crazy to see, now right before Christmas when many people buy these low-end cutters as gifts or to start a work-from-home gig. There is an old rule in the technology (and automotive) business. Don't ever buy V1.0 of anything. Let the early-adopters work out the bugs first. Proof here, right? 1 Share this post Link to post Share on other sites
