nutster44 5 Posted June 12, 2024 Hey guys, needing some help from an Adobe Illustrator guru. The file I have here I need to be 13.75 in. wide x 9.75 in. high. I was able to do this but I also need each star to be 1.254 in. high by 1.254 in wide, which I'm not able to do. Can anyone help with this...Thanks in advance guys... Flag Stars.ai Share this post Link to post Share on other sites
darcshadow 1,642 Posted June 12, 2024 If you change the size of the stars but want it to still fit in the 13.75x9.75 area the spacing between the stars will have to shrink. Are you ok with that? Also, the stars are not square, so if you make the a 1.254 square they will be distorted from the current design. You ok with that too? I use Inkscape so I don't know the exact commands to do this in AI but here is the process I took to create this. I took one of your stars, resized it then duplicated it 6 times to create the top row. Then I duplicated that row to create the the 5 rows. Then I selected and copied a 4x5 grid of the stars and shifted then down and to the right. Flag Stars.eps 1 Share this post Link to post Share on other sites
kainth.c.s 56 Posted June 14, 2024 Flag Stars.ai Flag Stars.pdf Share this post Link to post Share on other sites
