Robert Carter 0 Posted October 17, 2022 I have a us cutter with SCAL SC 2 is there a button for the cutter. to run out the film to be used to see if it is going to be straight? I think it's called an area test also I am running a Mac Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted October 17, 2022 Most any vinyl cutter has arrows to push to up, down, left, right on the control panel. Share this post Link to post Share on other sites
Robert Carter 0 Posted October 17, 2022 I knew I had that optionI was just wondering if SCAL had that option I'm use to illustrator which has that feature. Thanks for the reply Share this post Link to post Share on other sites
MZ SKEETER 4,727 Posted October 17, 2022 I don't know of any software, other that Graphtec Cutting controller that can do that. You should have HELP at the top of your layout screen. That IS usually your cutting software instructions.. There is only a handful of volunteers here that answer questions and none use SCALP software. Craftedge which makes SCALP software, has their own forum. , try that. Share this post Link to post Share on other sites
darcshadow 1,641 Posted October 17, 2022 Vinyl Master can do that, the plugin for Inkscape did as well I believe. Don't know about SCALP though, sorry. Share this post Link to post Share on other sites
