Clockmans 0 Posted July 28, 2021 So I just set up vinyl master on a new computer but cannot get this machine to calibrate. When I go to lasser offset full it says it can not find the Calibration File for this device. Also when I go to calibrate the arms offset it will not detect all the marks and I have tried and tried again and again. I am running a titan 3 along with vinylmaster pro. If anyone can help me it would be much appreciated. Quote Share this post Link to post Share on other sites
Guest stylesbykc Posted August 2, 2021 Same issue here! USC Support told me to contact futurecorp Quote Share this post Link to post Share on other sites
MZ SKEETER 4,682 Posted August 2, 2021 2 hours ago, Guest stylesbykc said: Same issue here! USC Support told me to contact futurecorp Futurecorp is your tech support for the software. UScutter cannot fix your software. Quote Share this post Link to post Share on other sites
Guest stylesbykc Posted August 3, 2021 Heres what i got from future corp 1. uninstall vinyl master 2. dowload this exact version https://fcws6.com/downloads/vm_usc/Install_VinylMaster_USC_MVS_2021_07_07.exe 3. run through the easy setup and connect your cutter 4. calibration should run just fine. It fixed it for me Quote Share this post Link to post Share on other sites
Dakotagrafx 7,292 Posted August 3, 2021 15 hours ago, Guest stylesbykc said: Heres what i got from future corp 1. uninstall vinyl master 2. dowload this exact version https://fcws6.com/downloads/vm_usc/Install_VinylMaster_USC_MVS_2021_07_07.exe 3. run through the easy setup and connect your cutter 4. calibration should run just fine. It fixed it for me thanks for posting the fix for others to look up in the future. if you sign up on the forum you don't have to wait for a mod to approve the post - it is free, no spam involved and become part of the community here supporting each other. glad you got it worked out! Quote Share this post Link to post Share on other sites
