Guest Theresa O Posted September 22, 2020 I need help and quickly if possible. I have the Vinylmaster LTR program. I need to cut 36" wide images in half, so was told I can use tiling to do this. I have watched videos, called US Cutter, emailed Future Corp for two days and still cannot figure this out!! Can someone please walk me through the steps...literally list step by step on what icons to click on to get this done. I am running out of time and am stressing!! Thanks! Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted September 22, 2020 You will get faster response times if you officially sign up to the forum. There is no charge. 2 Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted September 22, 2020 I don't know that tiling does anything to the actual image, I believe it does it all at cut time where it will break the image up to fit on your vinyl. If you actually want to cut the image in half, the easiest way in my opinion, Duplicate the image then draw a box that covers half of the image. Duplicate that box. Then punch one box through the image and do an intersection of the other box and other image. I don't remember the exact terms for doing this, I'm away from VM right now. When I get a chance later I'll look them up. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted September 23, 2020 Tiling is in VinylMaster PRO and DSR and not LTR. 3 Quote Share this post Link to post Share on other sites
