Guest Carl Posted September 18, 2020 Using Vinylmaster Cut........ is there a way to change the nudge setting for better control of where the imported image goes.... specifically when I line them up to match each other? Quote Share this post Link to post Share on other sites
slice&dice 2,455 Posted September 19, 2020 There is an ALIGNMENT function, which permits centering objects to each other, or to the sign area. You can look into the Help for exact details of how to adjust the nudge precision. It does have that control. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted September 23, 2020 This is managed in User Settings or Preferences. Please click the Help (menu) > Help Topics in the software to bring up the manual. You can use the Keyword search to find the topic that relates to this issue and/or expand out the folders to drill down to the topic. Search: Nudge 1 Quote Share this post Link to post Share on other sites
Guest Changing the NUDGE Posted December 1, 2020 hit F2, it's under general then under editing. When you get it changed and you nudge if it is not quite small enough you can hold down CTRL while nudging and it nudges half of whatever you have it set to do so you can do very miniscule nudging if needed. Good luck! Quote Share this post Link to post Share on other sites
Guest jus Posted January 2, 2022 What does nudge do? I am a beginner Quote Share this post Link to post Share on other sites
haumana 1,223 Posted January 3, 2022 1 hour ago, Guest jus said: What does nudge do? I am a beginner Image placement/alignment in small increments. It's helpful, especially when working on multi-color/layered designs. Quote Share this post Link to post Share on other sites
