Guest Bobby Posted April 11, 2020 Running a MH2 Plotter for 2 years now. Last night I was cutting a few sunroof decals. First one cut perfectly fine, went to do a second one for another customer and when I click “Cut Now”. It pops up the progress green bar but the plotter isn’t cutting. I’ve turned the plotter off and on, restarted the program as well as the computer, checked the connections with the Com 1 cable and it’s right, even went in and cleared out all the completed jobs from the memory. Why would it work one second and 5 minutes later not. This is the first time it has happened. Quote Share this post Link to post Share on other sites
haumana 1,220 Posted April 11, 2020 Could be several things. Does your cutter show that it’s receiving the job? It could be a bad cable. Quote Share this post Link to post Share on other sites
Wildgoose 4,200 Posted April 12, 2020 I have a couple USB ports that I have worn out and had to switch to another due to wear and tear Quote Share this post Link to post Share on other sites
darcshadow 1,627 Posted April 13, 2020 Does the cutter work when you hit the test button on the cutter? Quote Share this post Link to post Share on other sites
