tibgdm1 0 Posted April 2, 2017 I have been lucky enough to not encounter any block colour related issued sublimating photographic images onto mugs. However, I have been given a job that has blocks of red in the vector image. I have gone through 10 plus mugs using different tweaks in the image, driver settings, etc, but constantly produce a variety of pinks :-( and I'm now run out of options as well as mugs. I've exhausted forums, manufacturer/vendor settings and guidance without success :-( My configuration: All drivers are the latest to the OS, Sawgrass & Ricoh. OS: WINDOWS 7 SCREEN CALIBRATED: YES SOFTWARE: PHOTOSHOP CS5INKS: SAWGRASS SUBLIJET-R (LESS THAN 3 MONTHS OLD) PAPER: SAWGRASS TRUEPIX MUG: LONGFORTE ULTRA WHITE PRINTER: GELSPRINTER GX e7700N COLOUR HANDLING: PRINTER MANAGES COLOUR RENDERING INTENT: PERCEPTUAL IMAGES: SRGB DRIVERS: POWERDRIVER R GXE7700N V3.7.1.2814 WITH UNDERLYING OEM RPCS V4.51 I am using the standard sawgrass procedure for image creation and powerdriver printing. I have also used the PHOTO & VECTOR ICC print process from sawgrass which gives the same results. All other colours appear fine, its just the reds. I have included an image of my mug, created using the Wikipedia RGB RED values (https://simple.wikipedia.org/wiki/Red) with a variety of core reds that I wanted to reproduce alongside a colour calibration chart and a listawood mug from this years printwear & promotion 2017 show which has the red I desire. Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted April 2, 2017 you don't say what heat source your are using and have you tried varying the time heat is applied besides checking the accuracy of the eheat source? the pink can be caused by too much time or too little time. it is one area that adding more time makes things worse possibly Share this post Link to post Share on other sites
