Jhamelton 2 Posted November 15, 2016 Hey all. I'm making some memorial stickers with a plane on them. I got the look right and cut one out on a scrap piece to see how it looked. Is there anyway to get it to just cut the outside image of this plane (I've attached the image.) I don't want to deal with weeding all the detail, just need the look of a plane (silhouette??) I put it in wireframe mode to show the cuts. I'm only doing them one color. I'm learning, but still way new to this. Lol. I'm using vinylmaster cut. Thanks Quote Share this post Link to post Share on other sites
darcshadow 1,627 Posted November 15, 2016 Not sure what the name of the tool is in vinylmaster but you simply need to select all the objects that make up the aircraft and weld/merge/join them together. If the aircraft is already a single object, there should be a tool to break apart an object. Once you do that you can then select all the pieces and weld them together. That should give you the look you are going for. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted November 15, 2016 First work in wireframe so you see all the detail. Select the plane and take a copy of it and move it off... then from the Curve (menu) click Break Apart and then select the outside of the plane and move that off and send to the cutter. Quote Share this post Link to post Share on other sites
Jhamelton 2 Posted November 15, 2016 Awesome. I'll give it a try tonight. Thanks a bunch! Quote Share this post Link to post Share on other sites
Primal Decals 621 Posted November 15, 2016 airplane silhouettes------ https://www.vecteezy.com/vector-art/115415-biplane-silhouettes https://www.google.com/search?q=airplane+silhouette&safe=active&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwj21e-g3avQAhUGLSYKHW_FAsYQsAQIHA&biw=1847&bih=864 2 Quote Share this post Link to post Share on other sites
