busterbay 326 Posted May 26, 2016 I want to use VM on my design laptop and then use the computer hooked up to the cutter to cut. How do I do this ? VM wants my Serial # before it will install on my Laptop if I enter my Serial# won't it will disable the program my cut computer ? Quote Share this post Link to post Share on other sites
Go-C Graphics 856 Posted May 26, 2016 No it won't. You're allowed to have it on another computer. You can save your work as a VM file but you will not be allow to cut or export a different file format. But you can design and save. At least that's what I do. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted May 26, 2016 Multiple Copies - Installation You can install the software onto as many computers as you like and then design your work and save it off. However, if you want to output from a particular computer then it needs to be Activated and you get one Activation per license. Note: You can always Deactivate a computer and Activate another as many times as you like. 1 Quote Share this post Link to post Share on other sites
busterbay 326 Posted May 26, 2016 Multiple Copies - Installation You can install the software onto as many computers as you like and then design your work and save it off. However, if you want to output from a particular computer then it needs to be Activated and you get one Activation per license. Note: You can always Deactivate a computer and Activate another as many times as you like. That's Awesome, how do I get past the needing my serial number for the install ? The USCutter version I have won't install without the serial any insight would be very helpful. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted May 27, 2016 The PSN does not unlock (activate) the software it merely allows you to install the software. Then you can choose whether or not to activate VinylMaster. If you don't activate it, you can still use the software to design and save off your work (which you can open on another computer) but cannot output from it. This means you can have one activated computer for cutting/exporting/printing and as many computers as you like to design and save on. 1 Quote Share this post Link to post Share on other sites
gilby7887 0 Posted May 29, 2016 I have a Microsoft surface that i have VM installed on if i'm out of town or laying in bed/living room i can still design and save to thumb drive and cut from my work computer cause its the one that's activated. Quote Share this post Link to post Share on other sites
Guest swhit Posted July 15, 2016 My surface won't even allow me to install vm Quote Share this post Link to post Share on other sites
OWJones 1,981 Posted July 16, 2016 5 hours ago, Guest swhit said: My surface won't even allow me to install vm Which version of the Surface do you have? I think the first version was Windows RT, not real Windows - but I could be mistaken... Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted July 17, 2016 Also check the space available on the target drive. Quote Share this post Link to post Share on other sites
