dansell 12 Posted August 20, 2015 Does anyone get good cuts with their Graphtec 6000 and Vinyl Master Pro? I hope someone can help me. I finally bought my Graphtec CE 6000. I was using Vinylmaster pro with a Laserpoint. I have Windows 8.1. I have talked with US cutters last week several times and they deemed that it is the software and not my new cutter. I get good cuts with Graphtec Studio and Illustrator with the Cutting master 3 plug in. The issue is that how I do all of my weekly orders, VInyl master is the most efficient and I like the weeding options better. I have a support ticket in at Vinylmaster but I am still waiting. Bade offset is at 0 Here are some images of the the cuts that I am getting with VInylmaster. I have the language set at GPGL. I sure hope that I have provided enough information. Thank you in advance for any help. Share this post Link to post Share on other sites
MZ SKEETER 4,726 Posted August 20, 2015 Command should be HP-GL for any software other than Graphtec language which is GP-GL 1 Share this post Link to post Share on other sites
dansell 12 Posted August 20, 2015 Oh and here are some samples of cuts from graphtec Studio Share this post Link to post Share on other sites
MZ SKEETER 4,726 Posted August 20, 2015 Put the cutter on the correct Command Language.. HP-GL.. Share this post Link to post Share on other sites
dansell 12 Posted August 20, 2015 I get this error message ( changed through the machine menu) Share this post Link to post Share on other sites
dansell 12 Posted August 20, 2015 I get this error message ( changed through the machine menu) I hit enter to confirm and tried to cut and it just said processing, and machine went to ready, but nothing cut and no other messages popped up. Share this post Link to post Share on other sites
dansell 12 Posted August 20, 2015 Oh and I have uninstalled and reinstalled vmp too.... with a pc restart. Just tryin to tell you all what I have tried. Share this post Link to post Share on other sites
MZ SKEETER 4,726 Posted August 20, 2015 Have your downloaded the Ce6000 driver from the website? Or your CD? Many others are using Vinyl Master with their Graphtecs. Share this post Link to post Share on other sites
dansell 12 Posted August 20, 2015 I downloaded the driver from graphtec site.... I also went through the VMP wizard to install the driver Share this post Link to post Share on other sites
MZ SKEETER 4,726 Posted August 20, 2015 So make sure it says HP-GL in your cutting software as well as your vinyl cutter. Maybe someone using Vinyl Master can help you. I use Flexistarter software, which also has to be on HP-GL command language. I don't know anything about Vinyl Master. but any software that you use other than Graphtec software has to be on HP-GL Share this post Link to post Share on other sites
dansell 12 Posted August 20, 2015 Hot Damm!!!!! I could kiss you all!!!! Thank you so much!!!! The HPGL needed to be set in the software as well as the machine!!!!!! You guys are AWESOME!!!!!! 2 Share this post Link to post Share on other sites
MZ SKEETER 4,726 Posted August 20, 2015 Looks great, glad you got it. 1 Share this post Link to post Share on other sites
Quitetitan4 90 Posted August 20, 2015 Beautiful as a Graph technology should be! ! Congrats btw. Share this post Link to post Share on other sites
dansell 12 Posted August 20, 2015 Thanks!!! Now I can really appreciate this machine in the capacity that I wanted to!!!! Share this post Link to post Share on other sites
Quitetitan4 90 Posted August 20, 2015 Stupid auto correct! ! Hope to upgrade one day!! 1 Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted August 20, 2015 Command should be HP-GL for any software other than Graphtec language which is GP-GL I'm sorry Mz. Skeeter has been telling you to change it to HP-GL Since her first post why didn't you just read her first comment and follow through? She is very very knowledgeable with the Graphtecs. I know I know frustration over ruled any calm thinking right? been there done that. Share this post Link to post Share on other sites
dansell 12 Posted August 20, 2015 I'm sorry Mz. Skeeter has been telling you to change it to HP-GL Since her first post why didn't you just read her first comment and follow through? She is very very knowledgeable with the Graphtecs. I know I know frustration over ruled any calm thinking right? been there done that. I did follow through with the first suggestion, I changed it to HPGL on the machine and that is when I got the error message on my machine that I posted a picture of. I was unaware of needing to change it in the software program too. She then told me to change it in the software too and it fixed my issue, so I DID follow through with her instructions from the very get go. Mz Skeeter - I thank you again for your help!! 4 Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted August 21, 2015 I did follow through with the first suggestion, I changed it to HPGL on the machine and that is when I got the error message on my machine that I posted a picture of. I was unaware of needing to change it in the software program too. She then told me to change it in the software too and it fixed my issue, so I DID follow through with her instructions from the very get go. Mz Skeeter - I thank you again for your help!! I know you did I saw the test cut. I've been in a funk all day and I let loose sorry. Share this post Link to post Share on other sites
dansell 12 Posted August 21, 2015 No problem - I'm just happy that I got it working and thought if I posted step by step of what I was doing and the messages that I got, it might help someone else if they have the same issue. 4 Share this post Link to post Share on other sites
Coaster36 327 Posted August 21, 2015 Look at that, mine wasnt set to HPGL either. You save the day again Mz Skeeter. I was thinking my cuts were a little off since I installed vinylmaster. 1 Share this post Link to post Share on other sites
dansell 12 Posted August 21, 2015 Awesome Andrew!!!! I'm glad I posted!! Share this post Link to post Share on other sites
Camel 7 Posted March 26, 2016 Add another person saved by this post. I spent from 12 noon to 11 pm trying to figure out why my laserpoint cutter was cutting better than the new graphtec CE6000-60.... Set machine and vinylmaster to hp-gl and good as gold. THANKS! Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted March 26, 2016 Add another person saved by this post. I spent from 12 noon to 11 pm trying to figure out why my laserpoint cutter was cutting better than the new graphtec CE6000-60.... Set machine and vinylmaster to hp-gl and good as gold.THANKS! that's the beauty of the forum - it helps more people night and day without the phone calls to support 1 Share this post Link to post Share on other sites
Camel 7 Posted March 26, 2016 Just a follow-up, I discovered that with the language changed to hpgl the graphtec didn't "advance after cut" properly in vinylmaster (worked in signblazer), it actually went the opposite way. After a few ... long... hours I tried different languages and found hpgl_rel fixed this and still cuts properly. Share this post Link to post Share on other sites
dansell 12 Posted March 27, 2016 Hmmm... that is one thing that bugs me, I will have to check that out. I still love this machine! Thanks for the update! Share this post Link to post Share on other sites
