eddieb378 41 Posted June 13, 2014 How do I save my speed and force settings so when I cut my cutter off and cut it back on it's the same as when I left it?Also how do I change the baud setting on the cutter mine?Thanks in advance for any help I can get Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 13, 2014 For some reason, the MH series cutters will not remember the speed and force when the machine is turned off & on. The Baud rate is a software (not hardware) setting --- in SBE go to Cutter Settings/ COMM settings Share this post Link to post Share on other sites
eddieb378 41 Posted June 13, 2014 So the Titan 2 is in the MH series? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 13, 2014 So the Titan 2 is in the MH series? No relation to each other - the titan is much more advanced than the mh and has a true usb port - not emulated. can't answer the baud rate question as I only used usb with my titan when i had it - never a problem. why are you using serial with it? Share this post Link to post Share on other sites
eddieb378 41 Posted June 13, 2014 ok first let me explain what I am doing,I am trying to get my titan 2 to work with signblazer and I know on my copam the baud setting on the cutter had to match with signblazer and I could adjust it on the cutter and on the signblazer set up page.It was always 9600 on the copam but on the titan 2 it is 38600 I think I matched that and still no ability to cut.I got everything set like on the thread I seen the setup of someone else who is using signblazer with the titan 2.I will keep playing aroumd I am sure I am just missing something Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 13, 2014 Are you saying that the Titan II will revert back to the default settings of force & speed each time you cycle it off & on? I know my MH cutter did that, and it drove me nuts, and when I started using an SC machine I was glad it remembered whatever numbers had been dialed-in previously. If the Titan does NOT remember the force & speed, then I consider that a major design flaw and someone should be looking into getting fixed that at the factory, ASAP. As for the baud rate, it's right there within the SBE --- go to Cutter Settings/ COMM settings button. Share this post Link to post Share on other sites
plain ol Bill 20 Posted June 13, 2014 I am anxious to see the answer to the reset on the Titan also. I anticipate putting in my order for one next week. Share this post Link to post Share on other sites
eddieb378 41 Posted June 13, 2014 Yes everytime I cut my Titan 2 off and cut it back on I have to reset the force and speed.It could be error on my part that is why i was hoping someone with one would tell me if there's do it Share this post Link to post Share on other sites
DCMoney 91 Posted June 16, 2014 Mine keeps the last used settings. 1 Share this post Link to post Share on other sites
BannerJohn 1,324 Posted June 16, 2014 Mine keeps the last used settings. ditto Share this post Link to post Share on other sites
Go-C Graphics 856 Posted June 16, 2014 If I remember correctly my MH saved the last settings also. Share this post Link to post Share on other sites
Mel16 20 Posted June 17, 2014 My Titan 2 also keeps the last used settings. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 17, 2014 not sure on the titan but on the grraphtec I can change the setting on the plotter from within flexisign or graphtecs cutting controller - now it has been a long time since i used signblazer but is there a setting in the cutting part that could be resetting those from there? Share this post Link to post Share on other sites
eddieb378 41 Posted June 26, 2014 For some reason it is now saving them all of a sudden!thanks guys for the help Share this post Link to post Share on other sites
