Go-C Graphics 856 Posted March 29, 2014 I have a file I made in inkscape and saved as a .svg. When I try to save it as an .eps so that i can open it in flexistarter it drops the bottom decal. The bottom decal was a direct copy from the top left decal and all I did was weld in a box on the gray to that it wouldn't show the black anymore. Can someone please explain to me why it's doing this? I've attached the svg and eps files. SRT8 front emblem 3.1.eps SRT8 front emblem 3.1.svg Share this post Link to post Share on other sites
skarekrow 1,842 Posted March 29, 2014 Bounding box or stroke settings perhaps? I don't use Flexi but, SignCut is fussy about Strokes. Share this post Link to post Share on other sites
SeeJaysPlace 476 Posted March 29, 2014 or group it? Share this post Link to post Share on other sites
skarekrow 1,842 Posted March 29, 2014 Also, if you used control/command D to duplicate it, I have had occasion where I needed to OBJECT> PATH it. Share this post Link to post Share on other sites
Go-C Graphics 856 Posted March 29, 2014 Bounding box or stroke settings perhaps?I don't use Flexi but, SignCut is fussy about Strokes. There are no strokes that I can find or group it? Tried it, didn't change anything Also, if you used control/command D to duplicate it, I have had occasion where I needed to OBJECT> PATH it. I thought this might work but still no luck. I tried one other thing and it worked. I saved it as a pdf and it opened in flexi. This is SO weird because I've NEVER had a problem like this. 1 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted March 31, 2014 When I got Flexistarter I experimented with different formats to see what would work well in both Flexi and Corel X3 and I settled on pdf. Seems to be the format with the least headaches, at least for me. Share this post Link to post Share on other sites
