Tomkah 0 Posted January 30, 2014 Hello, I purchased an older Kingcut A360 USB without any software. Now I am trying to install it under Windows XP using the files at http://www.creation.com.hk/eng/support.asp, especially http://www.creation.com.hk/eng/uploadfile/download/A_series_driver.zip. As far as I understand, these usb cutters have a built in usb to rs232 port and that needs to be installed as a com port under windows...the only thing I can do with this driver is to install it as a "usb serial bus controller" called vectorsoft cutter board". It does not show up as under com ports at all. Does anybody happen to have the proper installation disk / cd or can anybody help with the problem? Btw, when downloading and unzipping the a_series_driver file, there is another driver called "paradriver0124.exe". When installing it, it creates a folder call commwatch, in which is another exe file, which lets me move the cutter head left to right etc. I also believe that this program creates 2 virtual com ports however my cutter is not associated with them and still listed as a "usb serial controller. Anyway, I hope this makes sense to somebody. Please help. Cheers, Thomas Share this post Link to post Share on other sites
dwp99 283 Posted January 30, 2014 Try here, this might help. http://www.creation.com.hk/eng/support.asp I couldn't get your links to work. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted January 30, 2014 I just opened my version of Signblazer Elements UK all cutter version ,and the Kingcut USB A630 is listed as a cutter on it. You can go to the Signblazer thread and download it free. Download 3rd post down user CUTME http://forum.uscutter.com/index.php?/topic/20104-full-version-signblazer-download-all-cutters/ Share this post Link to post Share on other sites
slice&dice 2,451 Posted January 30, 2014 One of your countrymen, a guy named Jerry Bonham (now deceased, unfortunately) developed a cutting program that is kick-ass, and it contains the driver for your machine, you can probably get up and running in five minutes. http://www.mystat.com/Signblazer.zip (UK version with patch) Instruction document attached to this post. readme.txt Share this post Link to post Share on other sites
Tomkah 0 Posted January 30, 2014 Hi guys, thanks for the warm welcome and your ideas etc. I tried the Signblazer software. It worked well, but my problem seems to be a different one. As far as I understand these USB plotters (or at least this one) the installation has 2 steps: 1) install the USB into Windows. This is much like one of those USB to RS232 cables, as it emulates a com port for all those "modern" laptops that are usb only. I use one of those for work to program satellite receivers. Now here is my problem as my cutter's "internal usb to rs232" if you will does not register with XP. I tried their "step by step with pictures" see here http://www.creation.com.hk/download/usb232.zip with their usb drivers here http://www.creation.com.hk/download/USB_32bit.zip as well as their a-series cutter drivers here http://www.creation.com.hk/eng/uploadfile/download/A_series_driver.zip but all I can do is install the thing as a "Vectorsoft cutting board" under "universal serial bus controllers". There is nothing like "virtual COM" or something in the com ports of the device manager. 2) software install. I am guessing that this "vectorsoft cutting board" is the actual machine...that seems to work fine. This is getting to me...I better pack it away for a while. Cheers, Thomas Share this post Link to post Share on other sites
Taleen 0 Posted June 29, 2014 Its says that this is a UK version, does it matter where you are? I know that sounds like a stupid question, but I am just making sure Share this post Link to post Share on other sites
jaybyrd 3,770 Posted June 29, 2014 Location doesn't matter but both versions have different cutters listed Share this post Link to post Share on other sites
slice&dice 2,451 Posted June 29, 2014 Won't work if you are in Madagascar. Share this post Link to post Share on other sites
