tamhelton 0 Posted January 19, 2014 USCutter SCPlotter won't turn on. i had this same problem when turned on machine for the first time, left it on for about 5 min and it suddenly came back on. Now it won't even turn on… HELP Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 19, 2014 Check the fuse and the switch wiring. Take off the cover at that end of the machine (two screws) and verify the integrity of the connections. Share this post Link to post Share on other sites
tamhelton 0 Posted January 19, 2014 OK Thank you, I will try. Share this post Link to post Share on other sites
tamhelton 0 Posted January 19, 2014 Did that however, didn't know what I was looking for. Everything seemed good. Share this post Link to post Share on other sites
tamhelton 0 Posted January 19, 2014 Is there a reset button? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 19, 2014 just for troubleshooting I would try another power cord on it after checking the above. there have been some bad cords in the past Share this post Link to post Share on other sites
smurfynecro1 0 Posted February 10, 2014 Having the same issue today. Haven't had my machine on or even plugged in for months and when I do it is directly connected to a surge protector. Changed fused (even though it wasn't even popped), tried a different cable, and then continued to open to check the connections. Everything is sound and no connections broke. Of course it goes down when I have work coming in... Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted February 10, 2014 Having the same issue today. Haven't had my machine on or even plugged in for months and when I do it is directly connected to a surge protector. Changed fused (even though it wasn't even popped), tried a different cable, and then continued to open to check the connections. Everything is sound and no connections broke. Of course it goes down when I have work coming in... Not to trying to be smart, but did you try a different surge protector? I have had the individual plug ins of the surge protector quit on them. 1 Share this post Link to post Share on other sites
xpaperman 719 Posted February 10, 2014 I have this issue with my SC on very rare occasions. I flip the switch and nothing happens. I just turn it of an back on again while giving the switch a little wiggle. It appears to me there must be a connection problem but I have not looked into it because it is so rare and the wiggle takes care of it. Might be a wiring issue on some SC's. Share this post Link to post Share on other sites
